  • 387
  • 49
Eyghon_VMSF
Fibre optic
Message 1 of 11
VM Tech Power Level Check Please
Can someone please do a Power Level check, look way out at the minute.
Craig
Operation ConfigOperation ConfigDownstreamDownstreamUpstreamUpstreamUpstream BurstUpstream Burst
  • 1.36K
  • 76
  • 317
cje85
Knows their stuff
Message 2 of 11
Re: VM Tech Power Level Check Please
The downstream is far too low, and upstream is slightly too high.
  • 2.96K
  • 378
  • 939
Message 3 of 11
Your downstream power levels are too low, the recommended range is -6 to +10 and all of yours are well below -6.  Also your upstream levels are too high.
This will need an engineer visit to sort out the power levels. You can call VM and try to book a visit or wait for the VM staff to get to this thread and they can help you book a visit.
If you want the forum team to assist with the booking let me know and I'll try to get them to have a look at this thread on Monday.  The forum staff have finished for the day and don't work Sundays so the earliest they can help you book a visit is Monday.
______________________
Scott
  • 387
  • 49
Eyghon_VMSF
Fibre optic
Message 4 of 11
Thanks guys,
My Upstream is generally solid @ around 48 with the Downstream rarely more than +/-2, more often than not it's pretty close to 0.
There were two outages on Tuesday last week, one in the early hours around 06.00 for 1-2 hours and then again 13:00 to around 18:30 BUT browsing has been bad for several days, just not got round to checking it. My SH2 has no FPA's at the minute so I will try one of those and call in on Monday.
Craig
  • 387
  • 49
Eyghon_VMSF
Fibre optic
Message 5 of 11
What are the Reg RSP errors?, don't recall seeing these before.
First TimeLast TimePriorityError NumberDescription
15/11/2016 08:19:51 GMT15/11/2016 08:19:51 GMTError (4)68000407TOD established
15/11/2016 08:19:45 GMT15/11/2016 08:19:45 GMTCritical (3)82000200No Ranging Response received - T3 time-out
15/11/2016 08:19:39 GMT15/11/2016 08:19:39 GMTNotice (6)84000510Downstream Locked Successfully
15/11/2016 08:19:29 GMT15/11/2016 08:19:29 GMTCritical (3)73000200REG RSP not received
15/11/2016 08:19:29 GMT15/11/2016 08:19:29 GMTError (4)73027100T6 Timeout and retries exceeded
15/11/2016 08:19:29 GMT15/11/2016 08:19:29 GMTCritical (3)73025103Registration RSP rejected unspecified reason
15/11/2016 08:19:29 GMT15/11/2016 08:19:29 GMTCritical (3)73025104Registration RSP rejected message syntax error
15/11/2016 08:19:28 GMT15/11/2016 08:19:28 GMTError (4)68000407TOD established
15/11/2016 08:19:21 GMT15/11/2016 08:19:21 GMTCritical (3)82000200No Ranging Response received - T3 time-out
15/11/2016 08:19:14 GMT15/11/2016 08:19:14 GMTNotice (6)84000510Downstream Locked Successfully
15/11/2016 08:19:04 GMT15/11/2016 08:19:04 GMTCritical (3)73000200REG RSP not received
15/11/2016 08:19:04 GMT15/11/2016 08:19:04 GMTError (4)73027100T6 Timeout and retries exceeded
15/11/2016 08:19:04 GMT15/11/2016 08:19:04 GMTCritical (3)73025103Registration RSP rejected unspecified reason
15/11/2016 08:19:04 GMT15/11/2016 08:19:04 GMTCritical (3)73025104Registration RSP rejected message syntax error
15/11/2016 08:19:03 GMT15/11/2016 08:19:03 GMTError (4)68000407TOD established
15/11/2016 08:18:56 GMT15/11/2016 08:18:56 GMTCritical (3)82000200No Ranging Response received - T3 time-out
15/11/2016 08:18:51 GMT15/11/2016 08:18:51 GMTNotice (6)84000510Downstream Locked Successfully
15/11/2016 08:18:42 GMT15/11/2016 08:18:42 GMTCritical (3)73000200REG RSP not received
15/11/2016 08:18:42 GMT15/11/2016 08:18:42 GMTError (4)73027100T6 Timeout and retries exceeded
15/11/2016 08:18:42 GMT15/11/2016 08:18:42 GMTCritical (3)73025103Registration RSP rejected unspecified reason
  • 2.96K
  • 378
  • 939
Message 6 of 11
I'm not familiar with those errors either.
Did you get a visit booked to sort out your power levels?
Scott
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Message 7 of 11
I'm no expert but I believe the REG RSP errors are Registration Requests (REG-REQ) which were sent to the CMTS without receiving a Registration Response (REG-RSP) within the  set timeout period.   So the modem resets its cable interface and restarts the registration process again.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 387
  • 49
Eyghon_VMSF
Fibre optic
Message 8 of 11
Yeah Scott, booked for tomorrow evening, I've also only had one Upload channel since Sunday too.
  • 387
  • 49
Eyghon_VMSF
Fibre optic
Message 9 of 11
SH2 was replaced with a SH3 this evening, where are the levels etc hidden in the SH3?, got the basic Info page showing the MAC, Software Version etc.
Craig
  • 2.96K
  • 378
  • 939
Message 10 of 11
I don't have a Hub 3, but I thought you could lookup power levels from the Router Status text link at the bottom of the login screen.
Scott
