RichandLucinda
Message 1 of 18
VIVID 300 but speed test indicates I'm getting 3Mbs
New install today.
Superhub has been put into modem mode - and am using the wired interface via a Sophos hardare firewall (was previously getting 20-50 Mbps on exact same network configuration with BT).
Not sure what to expect - but didn't expect that.
Have been running multiple speed tests via http://beta.speedtest.net/results
richard.
  • 509
  • 19
  • 171
Bartman007
Fibre optic
Message 2 of 18
Re: VIVID 300 but speed test indicates I'm getting 3Mbs
I would test without the firewall to rule that out, also post modem reading from 192.168.1.1, or in modem mode 192.168.100.1, Downstream, Upstream and Network log, don't forget you have 14 days cooling period, if you in a congested area it might be worth thinking about (read the rest of the Speed forum) as it can take over 3 years for VM to put their hands in their pocket to sort it out.
It could be a faulty connection, with any luck.
Rgards
All the information I provide is available on Google Search, I just make it simple for you Smiley Happy
  • 453
  • 9
  • 89
Bestie
Fibre optic
Message 3 of 18
First try the Virgin Hub in Modem mode connected directly to the PC via Gigabit Lan.
  • 509
  • 19
  • 171
Bartman007
Fibre optic
Message 4 of 18
He has Smiley Tongue
  • 362
  • 15
  • 83
pyrotenax
Fibre optic
Message 5 of 18
Just had mine swapped onto Vivid 300 this evening .... So far so good
5934666558
Running ASUS RT-AC88U with Asuswrt-Merlin firmware
RichandLucinda
Message 6 of 18
More details - from last night.
We lost the phone connection - so my wife called Virgin (go wives :-) - apparently we had a broadband specialist handle the phone call and we walked through some troubleshooting.
I connected a PC direct to the hub (no firewall) - and it was still very slow - the VM support tech claimed that he couldn't see the device attached to the hub (or rather the "voltages were low" - no I have never heard that before either )
I switched back to the router mode and retested with both a WIFI connection and the Wired connection - the WIFI gave a good 200+Mbs, but the wired was still ~3MBs.
These are multiple new cat6 cables so its not likely to be that.
Are all four ports the same ?
Currently this is on hold - the phone line means we might have a faulty external connection, and I'm away on business
We are currently 0 for 3 (in American speak)
  • No phone
  • No (usable) broadband
  • No TV (the Tivo couldn't get an IP address over the coax - VM is blaming my coax amplifier that was installed to put TV socket in every room).
RichandLucinda
Message 7 of 18
All working now - 311Mbps download / 17Mbps upload
We had a bad installation - the phone was incompletely disconnected from BT and the broadband had a lose connection in the street.
Wife is very happy with the performance of iPlayer :-)
  • 362
  • 15
  • 83
pyrotenax
Fibre optic
Message 8 of 18
Great news Smiley Happy
  • 125
  • 6
spritley
Dialled in
Message 9 of 18
So is there now a Vivid 300 instead of Homeworks?
  • 548
  • 31
arronlowley
Up to speed
Message 10 of 18
no it's not called vivid300, it called homeworks+300, homeworks is just the add on part.
http://www.thinkbroadband.com/ping/share/6c7f9a9f20c4b3cac9edc401f62167c3.html
