bentham7246
Just joined
VIVID 150 Optical Fibre - Area 20 - Slow Speeds
My connection speed is supposedly 150mbs  but at times i'm struggling to stream video.     Speed test websites say I have a speed of 28mbs.   Why is it so slow? it appears to be getting worse to be honest.    I don't have the Hub 3.0 so maybe I need that
  • 9.35K
  • 797
  • 1.96K
Re: VIVID 150 Optical Fibre - Area 20 - Slow Speeds
How are you connecting wired or wirelessly?
If wireless, try wired directly to the hub with a Cat 5e cable or better with a device equiped with a gigabit ethernet network card.
I would test the speeds during the day and again during evening peak periods.
  • 13.15K
  • 377
  • 1.08K
Moderator
Moderator
Hi bentham7246,
Following on from griffin I can add that your connection looks in good shape from this end, the only slight concern being upstream power levels which are a touch on the high side and worth keeping an eye on.
Drop us a quick update if you continue to have any issues.
Cheers
Ralph_R
Forum Moderator
