  • 46
supershaun
Message 1 of 25
Upload speed
My upload speed only 12mbps on vivid 300 and should be 20mbps please someone help
  • 5.63K
  • 287
  • 1.24K
Message 2 of 25
Re: Upload speed
Have you reset your hub yet? Has the download gone to 300Mbs yet?
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 46
supershaun
Message 3 of 25
Re: Upload speed
Yes ive reset it and the download is roughly 320mbps
  • 46
supershaun
Message 4 of 25
Re: Upload speed
How long does it take for virgin worker to look at this as my upload speed is the same when should be 20+mbps
  • 5.63K
  • 287
  • 1.24K
Message 5 of 25
Re: Upload speed
Around a week roughly on forums. Will need to call up for a quicker response.
  • 770
  • 14
  • 120
tommey
Well-informed
Message 6 of 25
Re: Upload speed
Hi supershaun
Have you checked the superhub info to see what config file is loaded?
Go to http://192.168.100.1/ in a web browser do not log in just click the link that says Check router status.
Click the tab called Configuration and scroll down to Primary Upstream Service Flow and post here what you see for Max Traffic Rate
If you are on the VM 300/20 package it should see a Max Traffic Rate of 22000000 for Upstream if its lower than that you will be better of calling as waiting here for a reply may take a week sometimes longer.
Hope you get it sorted
This is the poor quality of my Superhub 3 connection Smiley Sad
My Broadband Ping - Vivid 200 Gamer
- First reported 09/2014 - Fault ticket raised 01/01/15 -    - Review 01/05/15 - Review 12/08/15 - Review 14/10/15 - Review 04/11/15 - Review 15/04/16 - Review 06/07/16 - Review 31/09/16 - Review 30/11/16 - Review 15/02/17 - Review 12/07/17 - Review 20/09/17 - Review 14/06/17 - Review 10/01/18 - Review 25/04/18 - F004670584 << 3 YEARS+
But with BT Fibre I can actually game without lag Smiley Very Happy
My Broadband Ping - BT FIBRE 80/20
  • 5.63K
  • 287
  • 1.24K
Message 7 of 25
Re: Upload speed
It will be on there correctly as they have the 300Mbs download already @tommey
The profiles are not separated between download and upload they are one unit and 300/20 is the only option.
  • 770
  • 14
  • 120
tommey
Well-informed
Message 8 of 25
Re: Upload speed
Yup I know that but I had 300/12 at one point and had to have an homeworks+ config loaded to get 300/20, this was way before the new packages launched however.
so just asked him to check, what harm can it do
  • 358
  • 5
  • 21
chutwutt
Superfast
Message 9 of 25
Re: Upload speed
Move house ....or get off Vm ... and Im not being sarcastic!
tommey
  • 46
supershaun
Message 10 of 25
Re: Upload speed
