  • 16
ravickas
Message 1 of 11
Upload speed
Hello http://www.speedtest.net/my-result/6083063260   Hello ive got problem with my upload speed after i use my PC for like 2-3 hours its always goes down i dont know whats wrong with that?
http://www.speedtest.net/my-result/5994764080
  • 22.23K
  • 845
  • 3.23K
Message 2 of 11
Re: Upload speed
  • 16
ravickas
Message 3 of 11
Re: Upload speed
i used this internet like for more 6 months and never get downed upload speed its just started 3 days ago
  • 16
ravickas
Message 4 of 11
Re: Upload speed
So as i understood its will be like that always after i highly use upload they will cut my upload speed for 1h. what a shame for Virgin Media.
  • 16
ravickas
Message 5 of 11
Re: Upload speed
So they made this treshold from when? so it means if i stream something for a long time i lose my upload speed for a 60minutes and i cant stream for that time to get my upload speed back? so for what im paying money?
  • 16
ravickas
Message 6 of 11
Re: Upload speed
i hope so i will get usefull answer because i used this superfibre70 more like 6months and only 3 days ago i get upload speed loss. and its not fair i think.. i pay for 5mb/s upload not for like 1mb/s
  • 5.63K
  • 287
  • 1.24K
Message 7 of 11
Re: Upload speed
You pay for 'up to' speeds and all the terms and conditions of fair use were there when you signed up. Ignorance is not an excuse.
And mainly you pay for download with them. Part of the docsis trade off.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 16
ravickas
Message 8 of 11
Re: Upload speed
 so they wont change this tab if i use highly upload they always down my upload for 60minutes yes? and from then they made like that?
  • 5.63K
  • 287
  • 1.24K
Message 9 of 11
Re: Upload speed
If you upload more than the limit in the set amount of time, they will cap your upload speed for 60minutes yes (to 50). If you then breach the 2nd threshhold they will lower the upload some more (to 35%).
If you require a larger upload cap then you will need to upgrade your package to a larger one, or consider going to the gamer package which does not have an upload cap.
  • 22.23K
  • 845
  • 3.23K
Message 10 of 11
Re: Upload speed
to add to what Shafreya said the upload Traffic Management has been in place for many years (6+ years) so it was part of the terms when you signed up. You may of never noticed it or triggered it before but its always been there
