  • 19
lajosnagy17
Upload speed
Channel IDFrequency(Hz)ModePower
(dBmV)ModulationChannel Bandwidth(Hz)Symbol Rate (ksps)
3345800000 AT DMA41 32 qam 6400000 5120
3653700000 AT DMA41 32 qam 6400000 5120
Hi all,
I have checked my HUB 3.0 Upstream bonded channels and my question is the modulation.
Should not be 64 qam? I am getting the promised 20Mbs speed, so the speed is not the problem.
  • 5.35K
  • 271
  • 1.18K
Re: Upload speed
Depends on your CMTS. As/when the CMTSs get upgraded you may go up to 2/3/4 64QAM channels. It's not necessary for the speed as you have pointed out.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
