sahan123
Update from 50mb to VIVID 200 Optical Fibre
Update from 50mbs to VIVID 200 Optical Fibre but the broad band speed become more slower than 50 mb . It is now 25 - 30 mb .Can anyone help me out pls.
  • 9.02K
  • 760
  • 1.88K
Re: Update from 50mb to VIVID 200 Optical Fibre
How are you connecting wired or wirelessly?
If wireless, try wired directly to the hub with a Cat 5e cable or better with a device equiped with a gigabit ethernet network card.
  • 13.02K
  • 372
  • 1.06K
Moderator
Moderator
Hi sahan123,
Just to add to griffins thoughts, I can confirm that our engineers are currently investigating an SNR fault on your cable which may be impacting speeds - ref F004999142, hopefully we'll have this resolved ASAP for you.
Kind rgds
Ralph_R
Forum Moderator
