  • 15
lrc123
Message 1 of 26
Unusable broadband
I've been directed to this forum by your Twitter team, after being lied to on two occasions by the team on the phone.
My 70Mbps connection is down to 4 or 5Mpbs during peak times, aka whenever I'm at home and awake. I've done multiple modem resets and all my speed tests are done wired and I'm getting really fed up with Virgin.
I have been told it is a contention issue, which is particularly frustrating, as it isn't too long ago since I had the same issue, also due to contention - if you can't support your existing customers, don't keep signing up new ones!
The times I have spoken to customer service, I was told (on the 24th January) I would get a call back from the networks team within a few hours - I'm still to get that call. On the 3rd February, I was told an engineer would be out on the 4th February, so I waited in all day, no sign of an engineer. Broadband connection is still unusable.
At least when this happened before, my bill was reduced to compensate for the unusable connection. This time I'm paying more for a "faster speed", yet I'm still paying the increased price, but having to use the hotspot from my mobile if I want to get online.
How can I get this sorted so I can use my internet connection again?
  • 8.64K
  • 552
  • 2.39K
Message 2 of 26
Re: Unusable broadband
If its overutilisation, you cant "get it sorted" you just got to wait until it gets fixed. Could be a long wait.
You should have been issued an F number which allows you to claim a service credit going forward.
If not wait for staff to pick it up and they will get you one if it IS overutilisation.
Do you get headline speeds off peak?
  • 15
lrc123
Message 3 of 26
Thanks.
No F number, from the team on the phone, I just got the impression that they wanted to get me off the phone as quickly as possible.
I do get near enough to claimed speeds early in the morning.
  • 8.64K
  • 552
  • 2.39K
Message 4 of 26
Ahead of staff replying (which can take a few days), set up a BQM
HERE
Run it for say 24 hrs, and post the result.
Dont forget youll need to make sure your super hub is configured to reply to ICMP echo requests...
That will confirm its utilisation and we can push for an F number and associated credit.
Just be aware, fixes take a long time, might be better to look for an alternative supplier in the sort term.
  • 15
lrc123
Message 5 of 26
Thanks.
I've sent that up.
I'm now into double digit speeds!
  • 15
lrc123
Message 6 of 26
This is what the monitor looks like:
My Broadband Ping - My Virgin Media
Getting < 5Mbps right now.
  • 8.64K
  • 552
  • 2.39K
Message 7 of 26
We need staff input on that one- if it IS overutilisation its mild.
  • 15
lrc123
Message 8 of 26
I'll keep an eye on it, as weeknights seem worse than weekends when this was from.
  • 15
lrc123
Message 9 of 26
Updated with a midweek graph:
Should I have had a response by now? Or has marking previous help as "helpful" tagged this thread as "solved", so it is being ignored?
  • 8.64K
  • 552
  • 2.39K
Message 10 of 26
Likkely so- and it takes around a week ATM for a staff reply
