  • 5
Mull447
Under 5% Speed problem
I have been a Virgin/N T L customer since dial-up days. A couple of years ago when max speed was 60 Mb I was getting around 30 Mb. Only 50 % of what I was paying for but knew 100% was not achievable. I have recently run the usual speed, equipment and connection status tests on my 200 Mb connection over a period of times and days and currently my download is between 8-11 and upload is HIGHER at 10-12?????. Under 5%. Unacceptable. As a final test before resorting to complaining I did a reboot on the router (SUPER hub 2) only to find, to my amazement, that speeds actually went DOWN to 4-5 download with upload still higher at only 6-7!!!!
I have never seen or heard of higher upload speeds over download so think I have a real problem here.
Any advice or suggestions would be appreciated (particularly if anyone from Virgin actually reads this)
  • 10.82K
  • 308
  • 631
Re: Under 5% Speed problem
Hiya Mull447,
I'm sorry to read that you are having issues with the broadband speeds. I know how frustrating this can be.
From checking your connection, the downstream power levels are too low and the upstream are too high. I would like to book an engineer appointment to check this for you. I've sent you a PM (purple envelope icon, right corner) requesting some details.
Hope to hear from you soon
Sam
