  • 16
TREVSF1
Message 1 of 25
There it was gone..........speed.....SH3
So on 31/3 I called Virgin to let them know my superhub2 had stopped working.
They arranged an engineer to call on 3/4. Later in the day the hub started working again but I kept the Monday appointment open to check everything. I ran a speedtest which gave me the usual 110 mbps on wireless and 160 Mbps on cable ( I am on 200 mbps ).
Monday arrived and Enginneer replaced hub with SH3, did his checks and left.
I ran speedtest and speed had dropped to 48 Mbps wireless and 89Mbps wired.
Rang virgin who arrived today, got their wifi gismos out and said 209 Mbps available and it must be my computer. My question is of course, how come I had 110 Mbps on Friday and Sunday but  now I have 48mbps and I have not changed anything on my laptop.
ADVICE PLEASE............
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Message 2 of 25
Re: There it was gone..........speed.....SH3
Connect to the sh3 at 192.168.0.1, don't login but click on check router status,
post the information you find here, including the configuration page, although remove your wan ip if it appears anywhere.
also on your computer's wired connection can you confirm that it has properly negotiated a gigabit connection just to cover all the bases.
  • 16
TREVSF1
Message 3 of 25
Router Dowenstream
Downstream bonded channels Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
12990000002.540.9256 qam13
23230000002.940.3256 qam16
33150000002.540.9256 qam15
43070000002.440.3256 qam14
52910000002.540.3256 qam12
62830000002.540.3256 qam11
72750000002.440.3256 qam10
82670000002.440.3256 qam9
92590000002.440.3256 qam8
102510000002.540.3256 qam7
112430000002.540.3256 qam6
12235000000340.3256 qam5
13227000000340.3256 qam4
14219000000340.3256 qam3
15211000000340.3256 qam2
162030000003.240.9256 qam1
Upstream bonded channels Channel ID Frequency(Hz) Mode Power
231000000ATDMA47.516 qam64000005120
324400000ATDMA47.516 qam64000005120
Operational Configuration General Configuration Value
Network access
Enabled
Maximum Number of CPEs
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
V0dea97109ea7aa00.cm
SFID40801
Max Traffic Rate230000000
Primary Upstream Service Flow
SFID40800
Max Traffic Rate12700000
Network Log Date And Time Error Number Event Description
2017-04-03 07:48:38.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-03 07:48:38.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-03 07:48:39.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-03 07:48:47.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-03 07:53:23.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-03 07:53:23.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-03 07:53:37.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-03 07:53:56.0069011000Disruption during SW download - RF removed
2017-04-03 07:56:01.0069010900Disruption during SW download - Power Failure
2017-04-03 07:56:15.0069010200SW Download INIT - Via Config file
2017-04-03 07:56:46.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-03 07:56:47.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-03 07:56:47.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-03 07:56:49.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-03 07:56:55.0069010800SW upgrade Failed after download - SW File corruption
2017-04-04 12:17:52.0069010200SW Download INIT - Via Config file
2017-04-04 12:32:21.0069011200SW download Successful - Via Config file
2017-04-06 19:24:51.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Not sure how to confirm wired connection negotating a gigabit connection,
Thanks Trev
  • 1.46K
  • 87
  • 343
cje85
Knows their stuff
Message 4 of 25
On the Hub 3, both WIFi networks share the same name. You may need to re-name them, otherwise your devices can automatically connect to the slower 2.4Ghz band rather than 5Ghz which is best for speed. To do this log in to your hub, go to Advanced Settings > Wireless > Security, then adjust both of the "Wireless Network Names" so they're not the same. Then re-connect your devices to the 5Ghz network and see if that improves the speed.
  • 16
TREVSF1
Message 5 of 25
I have already renamed them 2G and 5G. I can only connect to the 2G as my Samsung R730 has a Qualcom Atheros AR9285 wireless card that does not support 5Ghz.
My son is connecting on 5G at 86mbps on wireless at present.
The weird thing is I was connecting at 110Mbps on 2Ghz wireless (according to speedtest.net) until the changeover.
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Message 6 of 25
Hmm looks like your router failed trying to upgrade its software due to a corrupt file possible caused by loosing power during the download. this was a few days ago though and I'm not sure if lack of messages after means it updated silently.
probably worth unpluging the hub, waiting a bit and plugging it in again, if you haven't already tried done that in the last couple of days.
The rest of the levels look ok, although interestingly you have less channels then me 16, to my 24 even though you have twice my speed so maybe someone can explain that to me.
Regarding gigabit speed, assuming windows 10, right click the little network icon, open network and sharing centre and click on the network connection. in the status box that pops up it should say 1.0Gbps next to speed.
  • 16
TREVSF1
Message 7 of 25
Wi fi speed shows speed at 65 mbps, do I need to hard wire and check ?
  • 16
TREVSF1
Message 8 of 25
There seems to be a no reply on this link ?
  • 16
TREVSF1
Message 9 of 25
Great response from Virgin......er none.
Virgin techs online blame connection tomy home but virgin engineers claim they dont know ehat they are talking about its my computer......amazingfor a large company tohave such poor customer service
  • 10.82K
  • 308
  • 632
Message 10 of 25
Morning TREVSF1,
Welcome to the community. It's nice to have you here.
Apologies there is an issue with the broadband speeds since the upgrade of the equipment and for not getting to you sooner.
I've taken a look at your connection, the line and hub have come back as fine. I was unable to see any issues on the network that would cause this.
The first step we need to check, is speeds through a wired connection and whilst the Hub is in modem mode to see what speeds you achieve. This will eliminate other devices connected.
Once you have completed this, let us know the result, then we can continue with further diagnostics.
Speak soon
Sam
