  • 16
  • 7
GC1028
Superhub going on and off
I have my Superhub on all the time, its annoying when connection goes off then back on again then off.
Superhub, don't think so.
  • 10.82K
  • 308
  • 632
Re: Superhub going on and off
Hi GC1028,
Thanks for taking the time to post on the community.
My apologies you are experiencing intermittent broadband connection. I can imagine how annoying this must be.
When checking your connection, the router is showing as offline and not polling any data. Is the router turned off as not in use?
Are you able to post some router information please for us to check over? To do this type in 192.168.0.1 in the address bar, no need to sign in and click Check router status. Within here you will have downstream, upstream and network log. You can copy and paste this information, that would be great.
Do any of the lights change on the router at all?
Does this happen on both wired and wireless devices?
Let me know how you get on
Sam
  • 16
  • 7
GC1028
The router is turned on!
  • 10.82K
  • 308
  • 632
Evening GC1028,
Thanks for getting back to me and letting me know the router is turned on.
However, I am still unable to see any data on your connection, such as the power levels to see if they are within the correct range.
When you get chance if you can post the information I mentioned above, that would be very helpful.
Speak soon
Sam
