  • 6
lost_on_earth
Message 1 of 36
Super Hub 3 is slow....really slow. How to fix?
Hello
I really hope someone can shed some light on my issue with Broadband & WiFi.
So we had the Super Hub 3 installed a little over a month ago we're on a 150MB broadband or supposedly thats what we're on. I've experienced very slow speeds on WiFi I'm talking almost dial up speeds! & drop outs when I am only within 5 metres of the router in the same room. Prior to this we had the Super Hub 2 & never experienced any issues at all. I've checked this during quiet times & busy time & can't see any improvements. I've tried playing with the channels again no improvement. The drop outs don't happen too often (SH2 never had drop outs) but the speed is annoying the hell out of me. Speed test on WiFi are appalling it took me 2 minutes just to load the page to carry out a test, I have a PC connected directly to the router also & speedtests is okay I've not seen it go over 100MB tried & tested at various times including into the early hours. Even getting into the router takes forever! I've done a ping google.co.uk -t & I can see it drops out with request timed outs, again didn't have this with super hub 2. I've checked all the cable connections already & they all seems fine. Restarted numerous times also.
Speed test on Wifi:
5252831625
Downstream log:
Upstream log:
Network log:
Date And Time Error Number Event Description
2016-04-02 15:45:32.002417164308Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:29.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:29.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-02 16:08:38.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-02 16:08:41.0082000700Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-02 16:09:14.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-02 16:09:14.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-02 16:10:09.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-02 16:51:33.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-02 17:02:50.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-02 17:02:50.0068010600DHCP Renew - lease parameters tftp file-Vee7a9a364ea87600.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-03 23:13:56.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-07 14:36:06.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-08 22:06:08.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-08 22:06:08.0068010600DHCP Renew - lease parameters tftp file-Vee7a9a364ea87600.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-10 23:09:13.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-11 22:17:26.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-12 17:58:48.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-12 17:58:48.0068010600DHCP Renew - lease parameters tftp file-Vee7a9a364ea87600.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-13 20:49:39.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
tracert bbc.co.uk:
C:\Users\loe>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.244.22]
over a maximum of 30 hops:
1 92 ms 101 ms 101 ms 192.168.0.1
2 * 62 ms 101 ms 10.42.56.1
3 98 ms 104 ms 53 ms lutn-core-2b-xe-123-0.network.virginmedia.net [62.253.98.177]
4 * * * Request timed out.
5 32 ms 31 ms 19 ms nrth-bb-1c-ae0-0.network.virginmedia.net [62.254.42.134]
6 45 ms 38 ms 35 ms tele-ic-4-ae0-0.network.virginmedia.net [62.253.174.18]
7 36 ms 100 ms 101 ms pos6-1.rt0.thdo.bbc.co.uk [212.58.239.237]
8 * * * Request timed out.
9 * * * Request timed out.
10 131 ms 101 ms 102 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
11 117 ms 56 ms 52 ms 132.185.255.148
12 83 ms 34 ms 76 ms 212.58.244.22
Trace complete.
Does anyone know what on earth the issue is here & more importantly how I & I hope others can fix this.
Thanks!
  • 6
lost_on_earth
Message 2 of 36
Re: Super Hub 3 is slow....really slow. How to fix?
Still not seeing any improvements in fact I could swear it's got worse since I last posted & everyone been away this weekend so I can't its because of usage.  Again WiFi is atrocious.  Someone must have an idea of what's going here?  Support??
Status:
Downstream:
Upstream:
Network Log:
Network Log Date And Time Error Number Event Description
2016-04-17 08:03:50.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tracert bbc.co.uk:
Tracing route to bbc.co.uk [212.58.246.78]
1 10 ms 3 ms 6 ms 192.168.0.1
2 13 ms 12 ms 9 ms 10.42.56.1
3 13 ms 13 ms 15 ms lutn-core-2b-xe-123-0.network.virginmedia.net [62.253.98.177]
5 15 ms 13 ms 18 ms nrth-bb-1c-ae0-0.network.virginmedia.net [62.254.42.134]
6 21 ms 18 ms 20 ms tele-ic-4-ae0-0.network.virginmedia.net [62.253.174.18]
7 19 ms 24 ms 19 ms pos6-1.rt0.thdo.bbc.co.uk [212.58.239.237]
9 22 ms 25 ms 21 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
10 23 ms 23 ms 28 ms 132.185.255.165
11 21 ms 19 ms 34 ms 212.58.246.78
Trace complete.
  • 6
lost_on_earth
Message 3 of 36
Here's an update.
I put the router into Modem mode to test a few things maybe it needed an update from Virgin or something which wasn't being pushed, I'll trying anything now.  Done a speed test in modem mode & surprise surprise I'm still not getting what I am paying for I should be 150MB & like I said earlier I don't even get 100MB.  What is really intriguing is the Virgin Media Staff who answer posts on this forum.  It's been a few days since I posted my issue & I've noticed they've responded to other posts but not this??  Hell I've seen them post replies to posts within a few hours of OP posting but for this issue I've not heard a thing.  Virgin Media WHERE ARE YOU!!  I'm open to suggestions here.  I've posted detailed information regarding my issue but not heard a thing from you, are these not detailed enough?  Am I not being clear?  All I want as a paying customer is for you to fix this is it really too much to ask?
Speed test in Modem mode:
(no devices connected except PC)
5261066170
tracert bbc.co.uk in modem mode:
1 11 ms 9 ms 9 ms 10.42.56.1
2 8 ms 9 ms 9 ms lutn-core-2a-xe-123-0.network.virginmedia.net [62.253.98.169]
3 * * * Request timed out.
5 18 ms 15 ms 13 ms brhm-bb-1c-ae1-0.network.virginmedia.net [62.254.42.210]
6 40 ms 24 ms 19 ms tcl5-ic-2-ae0-0.network.virginmedia.net [212.250.15.210]
7 20 ms 18 ms 26 ms 212.58.239.249
10 21 ms 19 ms 19 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
11 20 ms 20 ms 22 ms 132.185.255.148
12 29 ms 52 ms 24 ms 212.58.244.22
Trace complete.
  • 6
lost_on_earth
Message 4 of 36
So I'm starting to discover a few things one of which is Virgin Media Customer service is horse sh#t but we'll come back to that.
I put the useless white brick they call 'Hub 3.0' back into router mode connected to WiFi on my laptop 2.4Ghz frequency & I kid you not I was setup right next the bloody thing & this is what I got:
5266405901
As you can see a 37ms ping test puts this connection firmly into the horse sh#t category & personally I don't like paying a lot of money for horse sh#t which is clearly what I'm doing here.  For anyone readying this whether your Virgin Media Support, unfortunate customer or a lucky non customer.  I can tell you from experience, clearly I have some here now, save yourself the pain go elsewhere.  Oh & I hope to receive a message from support soon or anyone, really anyone who understands what the hell is going on here I mean look at those numbers just look at them its appalling.
And here's another to confirm this definitely is horse sh#t again I had my laptop next to the useless white brick.
143960545
Downstream:
Upstream:
Network log:
2016-04-18 14:05:17.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-04-18 14:05:17.0068010600DHCP Renew - lease parameters tftp file-Vee7a9a364ea87600.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 5.78K
  • 294
  • 1.27K
Message 5 of 36
Just a heads up to you. Every time you bump your thread with a new post you are putting yourself to the back of a queue for a reply. VM usually take around 2 days from your last post to reply (longer over the weekend)
You had nothing apparently obvious in your power levels. Wired test showing 90Mbs has an indication that your Ethernet cable or Ethernet port is not gigabit capable so won't go over 90Mbs (unless this is a contention issue, if you do more wired speed tests at different times it would show this)
Wifi is its own minefield of interference, especially on the 2.4ghz band, so won't even comment on those wifi tests.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 14.48K
  • 641
  • 1.46K
Moderator
Moderator
Message 6 of 36
Hi Lost_on_earth,
Welcome to the forum and sorry to hear you're getting poor speeds. I've just checked your connection from here and can see no issues. Your power levels, SNR and area contention are all healthy. It sounds like Shafreya has hit the nail on the head in the post above. Could you check if your ethernet card is gigabit or 100/10?
  • 6
lost_on_earth
Message 7 of 36
It's been a while since my last post so I thought I'd give an update.  I tested the wired speed on my laptop which has a gigbit Ethernet port at various times & got varying speeds between 110 & 140.  As for the wireless I refuse to buy this excuse of interference 'minefield' as mentioned in my previous post I was using hub2 which NEVER had slow speeds as soon we moved to Hub3 it's been ridiculously slow on WiFi. Heres an example from today
5308361097
I find it hard to believe within the space of 20 minute (thats how long it took to install & initialise when we first got it) we went from excellent WiFi speeds on hub2 to this on hub3.  You cannot say there are interferences created in 20 minutes or that all my devices which need 2.4Ghz have miraculously developed a fault.  I have checked the WiFi signals of neighbours & they are no where near my channel for 2.4Ghz, there are no other WiFi transmitting devices in my house or the neighbours (yes I really have checked)  To me it seems there is a fault with these hub3 & Virgin Media are not acknowledging it.  I always thought with every new device there is innovation but with this I feel it's gone backwards.
Tags (1)
  • 7.79K
  • 190
  • 447
Message 8 of 36
Hi lost_on_earth,
Thanks for getting back in touch. I'm sorry to see you have continued to have trouble with your speeds on wireless.
I have had a look at your connection and things seem to be ok from this side.
A lot of things can affect a wireless signal. Even moving the hub by 90 degrees can improve or change the signal.
I can see you have already tried a lot of things, please have a look through this. If you're still not having any luck with it after that then we will see what we can do for the next step.
Speak to you soon.
Emma
  • 6
lost_on_earth
Message 9 of 36
Thank for for getting back to me.  I should point out I am already aware of the link you have provided & have pretty much tried everything on there & nothing has improved performance for devices on 2.4Ghz frequency.
I once again checked channels in my area & nothing is anywhere near the frequency I am using.
I have restarted numerous times since my last post to no avail.
I've done tests with my laptop literally sat next to the Hub 3.0 & in other rooms throughout the house & the performance is the same.
As mentioned in my earlier posts this annoying slow speed has orrcured since we switched to Hub 3.0 we never had these issues with Hub2, within the space of a 20 minutes it's almost back to dial up speeds. when I visit webpages I can actually see the ads & images loading bit by bit just like they used to in dial up days.
Did a speed test today & this is what I got on my laptop in the same room as the router.
5464014082
First, no where near what I had on Hub2 & second no where near the speeds I'm paying for.
Tracert bbc.co.uk
1 15 ms 20 ms 19 ms 192.168.0.1
2 54 ms 20 ms 20 ms 10.42.56.1
3 83 ms 25 ms 24 ms lutn-core-2b-xe-123-0.network.virginmedia.net [6
2.253.98.177]
5 84 ms * 123 ms nrth-bb-1c-ae0-0.network.virginmedia.net [62.254
.42.134]
6 105 ms 102 ms 52 ms tele-ic-4-ae0-0.network.virginmedia.net [62.253.
174.18]
7 42 ms 26 ms 27 ms pos6-1.rt0.thdo.bbc.co.uk [212.58.239.237]
9 91 ms 101 ms 101 ms ae0.er02.cwwtf.bbc.co.uk [132.185.254.90]
10 28 ms 25 ms 25 ms 132.185.255.165
11 45 ms 101 ms 101 ms 212.58.246.78
Trace complete.
Status
 Cable Modem Status Item Status Comments
Acquired Downstream Channel(Hz)
323000000
Locked
Ranged Upstream Channel(Hz)
45800000
Locked
Provisioning State
Online
Downstream
Downstream bonded channels Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
13230000006.840.9256 qam60
23150000006.640.9256 qam59
33070000006.843.3256 qam58
42430000006.643.3256 qam50
52350000006.840.9256 qam49
6299000000740.9256 qam57
7291000000740.9256 qam56
82830000007.143.3256 qam55
92750000006.943.3256 qam54
10267000000740.9256 qam53
112590000006.940.9256 qam52
122510000006.943.3256 qam51
Upstream
Upstream bonded channels Channel ID Frequency(Hz) Modulation Power
(dBmV) Mode Channel Bandwidth(Hz) Symbol Rate (ksps)
445800000ATDMA44.816 qam64000005120
535800000ATDMA44.816 qam64000005120
Configuration
Operational Configuration General Configuration Value
Network Access
Disabled
Max number of CPEs
1
Baseline Privacy
Enabled
Docsis mode
Docsis30
Configuration file
.iyewrkldJKDHSUBsgvc
SFID284
Max Traffic Rate165000000
Primary Upstream Service Flow
SFID283
Max Traffic Rate10500000
2016-06-30 11:05:06.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-01 13:09:54.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-01 13:09:54.0068010600DHCP Renew - lease parameters tftp file-Vee7a9a364ea87600.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-05 06:44:43.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-06 07:10:38.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-06 07:10:38.0068010600DHCP Renew - lease parameters tftp file-Vee7a9a364ea87600.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-06 17:05:10.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:04:40.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:04:40.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:04:41.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:04:46.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:05:13.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:06:17.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:06:17.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:07:37.0068000100DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:08:15.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:08:15.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:09:32.0068000100DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-07-07 20:10:32.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
So now I ask is this enough evidence to prove there are issues with your Hub 3.0 devices & will you finally fix the problem?
Tags (2)
  • 7.79K
  • 190
  • 447
Message 10 of 36
Hi lost_on_earth,
Thanks for getting back in touch. I'm sorry to see you are still having trouble.
As it seems to be ongoing and I can't see any reason for it from this side. I would like to get an engineer out to take a look.
Keep an eye out for the Purple Envelope, top right hand corner.
Speak to you soon.
Emma
