ablig
Sub 1 megabit upload speed in Bromley BR4 for last 10 days
My upload speed since 23rd March 2017 has consistently been under 1 megabit, typically speedtest.net shows 0.01 to 0.3 megabit range.
This is a significant issue for me with regards online devices I have, which require, 1Mbps for minimal connectivity.
This has been issue for nearly 10 days.
Having tested via the Virgin account portal, having checked cabling, plus restarted equipment several times, this permanent outage remains a problem.
Download (for my 200 megabit connection) is generally about 130 to 180megabits roughly recently, which is acceptable, so upload is the specific problem here.
As a Sam Knows user, my daily speed testing cycle shows the decline in speed from 23/03, and an increase in packet loss. Latency has not changed at any level.
Is this a common issue in the Bromley (BR4) area?
  • 770
  • 14
  • 120
tommey
Well-informed
Re: Sub 1 megabit upload speed in Bromley BR4 for last 10 days
Please post your hub stats
This is the poor quality of my Superhub 3 connection Smiley Sad
My Broadband Ping - Vivid 200 Gamer
- First reported 09/2014 - Fault ticket raised 01/01/15 -    - Review 01/05/15 - Review 12/08/15 - Review 14/10/15 - Review 04/11/15 - Review 15/04/16 - Review 06/07/16 - Review 31/09/16 - Review 30/11/16 - Review 15/02/17 - Review 12/07/17 - Review 20/09/17 - Review 14/06/17 - Review 10/01/18 - Review 25/04/18 - F004670584 << 3 YEARS+
But with BT Fibre I can actually game without lag Smiley Very Happy
My Broadband Ping - BT FIBRE 80/20
  • 18
deanchapman
My last download test, this evening showed 0.11Mbps - I am paying for a 50Mbps service!
Virgin Media have been round twice to check out my router and still I have a problem... Network congestion apparently.
In what other situation would you continue paying for such a poor service ?   Do Ofcom not care, do Trading Standards not care, how are Virgin Media allowed to get away with it?
  • 10.82K
  • 308
  • 632
Hi there ablig,
Thanks for taking the time to post on the community.
My apologies you are having an issue with your upload speeds.
Looking at your connection, there is an SNR (signal to noise ratio) fault reported in your area. The reference number is F005208881 and has a review date of 10th April.
Otherwise I was unable to see any issues with downstream/upstream traffic on the network. I can see you are using the Hub in modem mode, are you able to complete a speed test direct to the Hub without your equipment attached to see if there is a difference please?
Let us know how you get on
Sam
