  • 21
Apbirdwatcher
Message 1 of 36
Streaming Issues
200mb broadband and i cant stream anything without buffering issues?
I have it hard wired and its still buffering..different devices, i have modified settings on each device to get best anti buffering solutions, noting works.
I stream on p2p, netflix, websites, so am i being throttled, when i do speed tests im getting 120mb plus which should not be buffering at all..either i'm being throttled by virgins **bleep** traffic management system or the super hub 2 is only supershit.
can someone look at my connection settings at Virgin end and stop slowing me down, restricting streaming and generally screwing with my service please..
  • 5.76K
  • 293
  • 1.27K
Message 2 of 36
Re: Streaming Issues
There is no download traffic management. Except p2p traffic, which you say you use
You are right the Superhub is just a basic device, you can always invest in your own device however.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 10.82K
  • 309
  • 632
Message 3 of 36
Hi Apbirdwatcher
Thanks for taking the time to post back on the community.
My apologies that you are experiencing issues with your broadband connection.
I've checked your connection and there is a high peak time traffic fault in your area. Our networks team are investigating the problem and are improving bandwidth and performance to help with this issue. The reference number is F004275040 and with a review date of 19th October.
One of my colleagues will be in touch shortly with more information in regards to this issue.
Sam
  • 21
Apbirdwatcher
Message 4 of 36
Thanks for the reply... why does it take so long for somone to check speeds and faults?
What is a high peak time traffic fault..?? are you throttling my speeds, supposed to be 200mb but im gettimg between 30-60mb wired and the same for wireless (2.4ghz 30 and 5ghz 60)...nowhere near what i should get...i would expect more like 140-160 st least.. and i want a nice steady stable stream without high pings and packet loss..any chance of providing a stable service?
I am on a superhub 2..is this equipment not up to the job?
Why should it take until October 19th to look for a fault..lol. thats over 6 weeks!!
  • 21
Apbirdwatcher
Message 5 of 36
So ill assume that you dont know whats up with the horrible connection then?
You have oversold and cant give us anywherr near what you stated...
You should be took to trading standards for you awful service
What if i decide ill only pay a random factor of my monthly bill as i choose on performance...im sure you will **bleep** the bed if i and everyone else did this...
Sort this out now and not in two months because in two months of this crap and ill be back on sky
SORT IT NOW
  • 21
Apbirdwatcher
Message 6 of 36
http://www.speedtest.net/result/5602422346.png
 Upstream   US-1 US-2 US-3 US-4
Channel Type2.0N/AN/AN/A
Channel ID3N/AN/AN/A
Frequency (Hz)30200000N/AN/AN/A
Ranging StatusSuccessN/AN/AN/A
Modulation16QAMN/AN/AN/A
Symbol Rate (Sym/sec)5120000N/AN/AN/A
Mini-Slot Size4N/AN/AN/A
Power Level (dBmV)58.21N/AN/AN/A
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts11000
T4 Timeouts0000
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)299000000251000000259000000267000000275000000283000000291000000307000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID71234568
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)4.524.144.404.174.054.174.244.28
RxMER (dB)36.3936.3936.3936.1736.3936.6136.1736.17
Pre RS Errors98799092077210111051192212107910510182961052794968623
Post RS Errors316312962991351939905940
First TimeLast TimePriorityError NumberDescription
Time Not EstablishedTime Not EstablishedCritical (3)82000200No Ranging Response received - T3 time-out
  • 5.76K
  • 293
  • 1.27K
Message 7 of 36
Your upstream is broken. Power level is way too high and only 1 channel locked.
  • 21
Apbirdwatcher
Message 8 of 36
So will that affect my download speeds?
All tests were done wired and in peak time
  • 5.76K
  • 293
  • 1.27K
Message 9 of 36
It will effect your connection aye.
Needs bringing back down (power level) and also getting back to 2 channels.
  • 21
Apbirdwatcher
Message 10 of 36
Anyone from virgin reading this thread... fault so sort it out
