  • 27
Zylexm
Message 1 of 7
Sporadic speed and connection problems
As the subject suggests we have been dealing with some major problems with our broadband service over the past month or two. The superhub (used in router mode) constantly resets itself and turns itself off, the connection speed goes from decent to none existant within minutes. Force resetting the superhub sometimes doesn't do anything.
6ca6d46e3c
298cef8f26
If you need any more information please let me know, any help at all would be highly appreciated.
  • 27
Zylexm
Message 2 of 7
Re: Sporadic speed and connection problems
3 days later no reply and the service is just as bad if not worse.
20e7d975bc
9e9515437c
  • 8.29K
  • 516
  • 2.3K
Message 3 of 7
Can you set up a BQM
 HERE
 Run it for say 24 hrs, and post the result.
 Dont forget youll need to make sure your super hub is configured to reply to ICMP echo requests...
  • 9.01K
  • 760
  • 1.88K
Message 4 of 7
VM take about a week or so to respond to threads at the moment and bunping your thread will put it to the back of the queue again.
Your stats look fine, allthough the network logs may have proven useful.
Are you experiencing the problems on a wired or wireless connection?
Are you experiencing the problems all the time or only during evening peak times?
  • 27
Zylexm
Message 5 of 7
Here is a monitor for the 5th, there were no big downloads via steam or anything, just normal web surfing and youtube/twitch streaming.
af3ddb7669d66166c47a5c87ff7c45c1-05-12-2016
The only thing in the network log is a T4 time out, but the hub was reset recently.
  • 7.3K
  • 307
  • 520
Message 6 of 7
Hi Zylexm,
Thanks for posting!
Sorry to hear you're having trouble with your connection.
I'd like to take a look at this for you but I can't seem to find your account. I've sent you a private message (purple envelope at the top right of your screen) so I can grab some details from you.
Speak soon Smiley Very Happy
Josh
  • 27
Zylexm
Message 7 of 7
So after getting an upgrade from the old 120Mbit service to the 200Mbit service, and a new Hub 3 sent out this morning, setup went smoothly and so far i am seeing a vast improvement on the connection quality. Obviously this is before peak time so i will update once i've been able to test then.
But so far the improvement is clear and has been great.
