  • 13
dz-015
Message 1 of 10
Speedtest.net Reporting 0.2Mbps on Super Fibre 70 Broadband Service
Hi folks,
On average, 3 times a week, my wired and wireless internet performance will slow to a crawl. When I run a test from a wired PC using the Ookla website it reports a download speed of 0.2 Mbps and an upload speed of around 5Mbps.
If I reboot my superhub 2 or wiggle the coax connectors where the cable comes from outside, the download speed returns to 70Mbps - for a short while - then it's back to 0.2 Mbps.
I've ran the tests on the Virgin website and checked all my connections are secure. I've also replaced the Cat6 cable between the super hub and my Netgear router.
I'd really appreciate any advice!
Cheers,
Dave.
  • 13
dz-015
Message 2 of 10
Re: Speedtest.net Reporting 0.2Mbps on Super Fibre 70 Broadband Service
Downstream power levels from my super hubDownstream power levels from my super hub
  • 13
dz-015
Message 3 of 10
  • 5.63K
  • 287
  • 1.24K
Message 4 of 10
If wiggling the coax helps then I would say it's not connected tight enough.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 13
dz-015
Message 5 of 10
Hi Shafreya,
Thank you for your reply.
I have finger tightened the coax connectors then used a small spanner to fully tighten them, being careful not to use too much torque that it damages the assembly.
Kind regards,
Dave.
  • 26
  • 15
wayneuk0709
Message 6 of 10
You will find Virgin dont care what speeds you are getting. As long as you are paying your money for a very, very sub standard service, that's good enough for them.
Many,many thousands in the same boat and legally, they don't have to do a thing about it.
  • 13
dz-015
Message 7 of 10
Hi wayneuk0709,
That's really disheartening to hear.  It is very expensive compared to BT.
The network does seem really old (Cable Tel?)
Anyway thanks for all your help - I'll see when my contract is up.
Cheers,
Dave.This is what my Virgin service plug in to. lolThis is what my Virgin service plug in to. lol
  • 164
  • 48
nbcaldon
Superfast
Message 8 of 10
Hi Dz,
You should find the speed is OK all day but in the evening when you want to use it most, it will slow to a crawl.
Just too many users, probably, and still trying to pile more in.
  • 26
  • 15
wayneuk0709
Message 9 of 10
Yes, to be fair, if you don't work during the day in the week, the speeds should be great.
If you work during the day though, tough ;-)
  • 10.82K
  • 308
  • 632
Message 10 of 10
Hi dz-015,
Thanks for taking the time to post back on the community.
I'm sorry to read you are having issues with your broadband connection.
From checking your connection, the line and hub have come back as fine.
If you complete a speed test direct to the Super Hub, without your Netgear attached, is there a difference in speeds?
I am a little concerned that you have to move the coax cable to achieve the higher speeds. Is this still the case?
Look forward to hearing from you
Sam
