squizz1
Speedtest done - advice please
Hi, been having loading problems again with several attempts needed to progress through most websites. I've just done a speedtest via Ookla and results show Ping 8ms, Download 47Mbps and upload 12.36Mbps.
Are these figures good, bad or indifferent?
Any advice welcome.
Squizz
  • 9.48K
  • 650
  • 1.81K
Re: Speedtest done - advice please
from the upload speed you are on 200meg so 47 is not good or may not be - a lot depends how you are testing the speed - if its using wifi then that may be all you get as the device can limit the speed - if is wired from a pc with a gigabit lan card and a cat5e cable or better then its not good
so if the test is via wifi do a wired test - if the test is wired then post the upstream and downstream levels from the hub
____________________
Tony
