s1985al
Message 1 of 5
Speeds not as advertised
I'm only getting download speeds of around 25mbps when it should be 100. Is this normal?
  • 164
  • 48
nbcaldon
Superfast
Message 2 of 5
Re: Speeds not as advertised
Is that the speed you are getting during the day or the evening?
s1985al
Message 3 of 5
During the evening. It was actually around 15 it 25 and sometimes dropping even lower
  • 164
  • 48
nbcaldon
Superfast
Message 4 of 5
That's probably the best you will get in the evening if your area is as congested as ours.
In my experience, I reckon you can only count on 10% of full speed during the evening.
At least you are getting better than the 1MB/s we are getting here all day long.
  • 10.82K
  • 308
  • 632
Message 5 of 5
Hi s1985al,
Sorry to read you are experiencing slow broadband speeds.
From checking your connection, there is a high peak time traffic fault in your area which is causing slow speeds. The reference number is F004275040 and has a review date of 24th May. As this is a review date it can be subject to change.
Sam
