FWalker2015
Speed test
Hi our wifi speed is slow I'm struggling streaming using the firestick?not sure how to add picture but I've saved it to my album on here
  • 13
DoItWithV
Re: Speed test
  • 8.99K
  • 756
  • 1.87K
Re: Speed test
First of all I would test the actual speed of the internet conection by connecting a device directly to the hub by ethernet cable.
Wireless is too unrealiable to test the true speed of the connection as it is affected by maqny external influences.
If the wired speed is good then the problem lies on the wireless side. Best to find out what is causing your poor speed before jumping to ill-informed conclusions.
