Trusha
Speed problems past 6 months
I am getting low speed and paying for a 59 mbs. This has been ongoing for 6 months and when I called virgin they said that they were upgrading the servers and this would be completed by 30th Nov. I am getting 1 my download and 2 upload. In April I was gettin. 37.78 download and 5 + upload. This is ridiculous service. I try calling and it takes so long to get a response
  • 10.82K
  • 309
  • 632
Re: Speed problems past 6 months
Hi there Trusha,
My apologies that you are having issues with the broadband speeds.
I've managed to locate your account and there appears to be a high peak time traffic fault in your area which is causing slow speeds. Our networks team are investigating the problem and are improving bandwidth and performance to help with this issue. The reference number is F003834674 and has a review date of 26th April 2017.
One of my colleagues will be in touch with more information.
Sam
Trusha
Hi Sam
This is still an issue and it has been going on for a very long time now.
I have just down a speed test and the results are: download - 7.27 and upload 10
We should be getting about 50mbps download.
Please can you look into this ?
Trusha
  • 13.26K
  • 381
  • 1.09K
Moderator
Moderator
Hi Trusha,
I'd like into this further for you but am unable to locate your account or run any diagnostic checks on your service.
If you could please drop me PM with the name on the account and your post code I should be able to locate your details and investigate the slow speed issues for you.
Many thanks
Ralph_R
Forum Moderator
Trusha
Hi there
The postcode is BD13 2BG and the name on the account is ############
Trusha
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 8.94K
  • 387
  • 630
Hi Trusha,
Thanks for getting back to us!
I've run diagnostics on your equipment and you levels are all looking healthy at the moment. There are also no network issues currently affecting your connection.
Are you still experiencing slow speeds? If so, are you testing the connection wired or wireless?
Speak soon
Josh
