  • 5
Dunky2k
Speed issues after upgrade to Superhub 3
Hi there, wondered if anyone could assist with some spped issues that i am now experiencing after upgrading my service to TV6 & Superhub 3.
I was until the other day using a superhub 2 and was regularly getting speeds in excess of 200Mb regardless of time of day.
Since upgrading to Superhub 3 i now can barely get 100Mb regardless of the time of day, almost less than half of what i was getting without issues, the only thing that's changed is me getting a Superhub 3.
Below are some screengrabs of the downstream / upstream / network logs too see if anyone can spot any issues with the setup.
Channel
Frequency(Hz)
Power
(dBmV)
SNR
(dB)
Modulation
Channel ID
1
299000000
8.3
35.7
256 qam
17
2
323000000
8.1
36.3
256 qam
20
3
315000000
8.5
36.3
256 qam
19
4
307000000
8.5
35.7
256 qam
18
5
291000000
7.8
35
256 qam
16
6
283000000
8
35
256 qam
15
7
275000000
7.1
34.9
256 qam
14
8
267000000
7.4
34.4
256 qam
13
9
259000000
7.6
34.3
256 qam
12
10
251000000
7.9
33.9
256 qam
11
11
243000000
7.6
33.8
256 qam
10
12
235000000
7.6
33.8
256 qam
9
13
227000000
7.6
33.8
256 qam
8
14
219000000
7.8
33.8
256 qam
7
15
211000000
7.5
33.4
256 qam
6
16
203000000
7.5
33.4
256 qam
5
17
195000000
7.3
33.3
256 qam
4
18
187000000
7.9
33
256 qam
3
19
179000000
7.5
33
256 qam
2
20
171000000
7.5
32.6
256 qam
1
Channel ID
Frequency(Hz)
Mode
Power
(dBmV)
Modulation
Channel Bandwidth(Hz)
Symbol Rate (ksps)
27
23600000
ATDMA
43.3
64 qam
6400000
5120
25
36800000
ATDMA
43.3
64 qam
6400000
5120
Operational Configuration
General Configuration
Value
Network access
Enabled
Maximum Number of CPEs
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
V0dea97109ea7aa00.cm
SFID
80992
Max Traffic Rate
230000000
Primary Upstream Service Flow
SFID
80991
Max Traffic Rate
12700000
Date And Time
Error Number
Event Description
1970-01-01 00:01:41.00
82000200
1970-01-01 00:01:26.00
84020200
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
84020300
MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-04 10:58:08.00
82000200
2017-04-04 10:59:04.00
69010200
SW Download INIT - Via Config file
2017-04-04 10:59:15.00
84000700
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
84000500
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
84000700
84000500
2017-04-04 10:59:20.00
84020200
2017-04-04 10:59:30.00
84000700
2017-04-04 10:59:44.00
69010400
SW Upgrade Failed Before Download - Server not Present
69010600
SW upgrade Failed before download -TFTP Max Retry Exceeded
2017-04-04 11:40:08.00
68010100
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-04 11:51:26.00
68010400
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-04-04 12:58:25.00
68010100
2017-04-04 13:16:44.00
68010400
2017-04-05 02:34:59.00
82000200
2017-04-05 21:13:20.00
69010200
2017-04-05 21:24:29.00
69011200
SW download Successful - Via Config file
Thanks in advance for anyone that can point me in the right direction to resolving this issue.
  • 7.57K
  • 188
  • 441
Re: Speed issues after upgrade to Superhub 3
Hi Dunky2k,
Thanks for getting in touch, I am sorry to see you have been having with your new Hub.
I have taken a look and things seem to be ok from this side.
Are you using a wired or a wireless connection? If wireless try wired, pop the hub into mode only mode with the computer in safe mode with networking. Let us know if this makes a difference.
It may also help us to see a BQM so we get a better idea of what you are seeing from your side. (Please be aware that link is external and we're not responsible for its contents).
All the best.
Emma
  • 5
Dunky2k
Hi Emma,
Think things are sorted now, i already had a BQM running see below.
My Broadband Ping - VM Superhub 3
