  • 31
Amran
Message 1 of 36
Speed issue new customer
Hi I am new customer that signed up to virgin media 152mb service and speed is slow I am getting 30mb download and 12mb up and drops 15mb download, 12mb up on ethernet cable  and on wireless it ranges from 40 - 50mb download and 12mb upload speed, it sometimes drops to 13 - 20mb download aswell. Wondering why the slow speed and wanted to know if virgin media put me on the correct package? below are my downstream and upstream stats maybe someone can help me and check if everything look fine and if there any problem thanks
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)299000000267000000275000000283000000291000000307000000315000000323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID51234678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)4.164.714.244.474.093.993.943.72
RxMER (dB)38.2638.2637.9438.2638.2638.2637.9437.94
Pre RS Errors423367317939290305986985
Post RS Errors300295299934290305985985
Upstream  US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID18N/AN/A19
Frequency (Hz)39400000N/AN/A32600000
Ranging StatusSuccessOtherOtherSuccess
Modulation16QAMN/AN/A16QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size4N/AN/A4
Power Level (dBmV)42.50N/AN/A42.00
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
  • 413
  • 16
  • 78
Cyanyde
Fibre optic
Message 2 of 36
Re: Speed issue new customer
Nothing wrong with those stats that should be giving you a slow connection. You can also look in the operation configuration page of the router status to check which package your hub is set to. The max traffic rates for upstream and downstream will tell this.
Cy - I don't work for VM, just lurk these forums and (hopefully) help
  • 31
Amran
Message 3 of 36
Hi It look ok to me but what could be the reason why the speed is slow?
General Configuration
Network AccessAllowed
Maximum Number of CPEs1
Baseline PrivacyEnabled
DOCSIS ModeEuroDOCSIS 3.0
Config File
SFID43600
Max Traffic Rate168960000 bps
Max Traffic Burst10000 bytes
Min Traffic Rate0 bps
Primary Upstream Service Flow
SFID4910
Max Traffic Rate12600000 bps
Max Traffic Burst16320 bytes
Max Concatenated Burst16320 bytes
Scheduling TypeBest Effort
thanks
  • 9.48K
  • 650
  • 1.81K
Message 4 of 36
you are on 152 - so thats bits right
do a wired test with SH in modem mode and the pc in safe mode with networking - only the lan connector next to the coax works
can you confirm what SH you have - there are 3 - the model will be on the label and can you confirm what wifi and lan cards you are using also what devices you are doing wifi speed tests on
____________________
Tony
  • 31
Amran
Message 5 of 36
thanks for replying I tried doing that putting the super hub 2 in modem mode and PC in safe mode and speed i achieve is 32mb download and 12 up with Ethernet cable. Also I have the super hub 2ac version I unscrewed the coax cable and screwed it back in and done wireless test and achieved 152mb and 12mb upload but sometimes the speed varies from 101mb, 90mb, 70mb download been testing it for 2 days and stayed like that which is a improvement. Also I believe I will need a virgin media engineer visit because the installation was not done properly on the outside of the property here a picture below of how it was left I believe the connection meant to be covered with a brown plastic cover which the engineer failed to do.
http://lookpic.com/O/i2/696/R8eDXh9p.jpeg
  • 31
Amran
Message 6 of 36
Almost forgot I am using wireless n for wireless connection and for Ethernet I am using Broadcom netlink (tm) gigabit Ethernet.
  • 188
  • 11
  • 26
Smitherz87
Superfast
Message 7 of 36
Amran wrote:
Oh dear at the pic. Are you saying your wireless speeds are ok we are simply talking LAN speeds? Do you have another Ethernet cable to hand? I suggest try that first.
I am a Virgin Media Field Technician. All my replies are my own opinion.
  • 31
Amran
Message 8 of 36
thanks for replying my wireless speed is perfect now since i took off the coax cable from the superhub and screwed back in tight using my hand. and my lan speed for ethernet is slow i can only achieve 32mb download and 12mb upload.
  • 188
  • 11
  • 26
Smitherz87
Superfast
Message 9 of 36
All the connections do need to be tight throughout. It can impact on your SNR levels amongst other things. Is you computer stating your running at gigabit speeds? Try changing port in the hub as well as cable.
  • 14.38K
  • 640
  • 1.45K
Moderator
Moderator
Message 10 of 36
Hi Amran,
That pic is not right at all. I'd like to book a technician to get this sorted properly for you and have just sent you a PM to arrange this.
As to the speeds being slow on ethernet, do you know if your network cards are gigabit of 100mb. If 100mb this is likely an issue with the superhub ACs firmware. There is a new version of the firmware in trial that fixes this and this should be released very soon.
