  • 48
gordonuk
Message 1 of 7
Speed is 0.15kbps this is not acceptable
Speed is so bad its only 0.15kbps which is less than half of dial up, cannot open any websites cannot access email cannot do anything
india tech suppoprt dont care and blame me
cannot speak to anyone in uk tek support
  • 8.28K
  • 514
  • 2.3K
Message 2 of 7
Re: Speed is 0.15kbps this is not acceptable
What does a speed test from a PC wired to the HUB with a CAT5 cable say?
How are you normally connected to the HUB? Wired? Wireless?
  • 48
gordonuk
Message 3 of 7
outage happened 12.45am yessterday, came back at 2.45am and sppeds showkingly bad, hightest i had since then is 1.5mb but averaging under 1mb
was fine until 1245am as was getting 50mb
am fixed ether from hub to pc, never use wifi hate it
  • 48
gordonuk
Message 4 of 7
  • 8.28K
  • 514
  • 2.3K
Message 5 of 7
So we can help us to help you, can you
Go to your Superhub Log in screen
Do NOT log in.
Little button top right.....
Can you post Upstream, Downstream and Network logs.
Screen caps are nice, C&P will do- Don't stress about formatting if you C&P. Someone will get a look and see if there's anything obvious amiss.
  • 48
gordonuk
Message 6 of 7
12.jpg1
[MOD EDIT: Inappropriate Image removed (contains IP address), please review the Forum Guidelines]
  • 48
gordonuk
Message 7 of 7
its nothing to do with my hub or settings everything was fine untill the outage but fault F004896573 is the problem as still ausing issues despite saying its fixed
