  • 6
Mamiller1973
Speed drop
I got virgin installed on Saturday, checked speed 200mps, excellent or so I thought
Checked last night and it was down to 33mps?
Can anyone explain?
  • 2.96K
  • 378
  • 939
Re: Speed drop
Are you using a wired Ethernet connection to the VM hub or a wireless connection? Wireless is easily disrupted by a number of external factors, so a wired test is the best way to get a true picture of what speed your line is able to achieve. It also helps to pinpoint if the issue is with the wireless or your line.
Are you seeing slow speeds all day or only at peak times (typically 4pm-11pm weekdays and weekends)? Some areas are suffering with over utilisation, which results in very slow speeds at peak times but full speed at off peak times.
If wired off peak speeds are slow then some hub stats might help.  Go to http://192.168.0.1/ (or http://192.168.100.1/ if you are in modem mode) to get the VM hub GUI. Don't login but instead click on Router Status which is either a button in the top right of the screen or a text link at the bottom of the screen depending on which hub you have. Click on the Downstream, Upstream and Network Log sections and copy & paste the figures from those screens and post them here, don't worry about the formatting or you can post screenshots if that is easier. Be careful to edit out or obscure any reference to your WAN IP in the log to protect your privacy.
The community can have a look for you and see if anything in the figures looks wrong and advise accordingly. Or you can wait for the VM staff to pick up this thread (can take 7-10 days) and run checks on your line.
______________________
Scott
  • 7.26K
  • 304
  • 519
Re: Speed drop
Hi Mamiller1973,
Welcome to the Community!
Sorry to hear you're having trouble with your speeds.
I've run a diagnostic on your equipment and everything is looking great at the moment. Signal levels are all as they should be and there are no network faults in your area.
Have you been able to try any of the checks SCA1972 has posted? Are you still having issues with slow speeds?
Look forward to hearing from you! Smiley Very Happy
Josh
