hildegunn
Speed/connection
i am having a problem with my broadband it is being very slow, it keeps buffering and some times I loos the connection completely so I have had to reset the router twice and that only helps for a short time. I checked the status on my account and it should be working fine. What should I do?
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Re: Speed/connection
Hi hildegunn,
Thanks for posting! I am sorry to hear about your issues with poor performance. I apologise for any inconvenience caused.
I have run some checks from here and everything looks great! No errors or time outs inside the Hubs logs and all of your power levels are within the preferred ranges.
Are you still having these issues? If so, please respond to me here with a recent copy of your Hubs logs for me to compare with the data we have here. You can find these by opening your internet browser and typing 192.168.0.1 into the address bar. Before logging in, in the top right hand corner it will say 'Router Status' click there and all of the information needed is inside.
Also, how are you connected wired or wireless?
Speak soon,
Adam.
hildegunn
thank you for getting back to me I am still having problems. I use wireless. This is what it is saying on the status report.
Acquired Downstream Channel (Hz): status 299000000, comment locked
Ranged Upstream Channel (Hz): status 31000000, comment successes
Provisioning State: status OK, comment operational
regards
Hildegunn
  • 3.88K
  • 120
  • 203
Hi Hildegunn,
Thanks for the swift response!
I appreciate you letting me know that you connect through the wireless. Have you tried changing the wireless channels to see if that improves performance?
Also, here's some useful information on optimising your wireless connection.
Could you also run a speed test with the Hub in modem mode connected directly via ethernet cable to the computer running in safe mode with networking and post the results here for us too see.
Take care,
Adam.
hildegunn
I am sorry, but I can´t do that because I don´t have a cable or able to use one with my pc.
Hildegunn
  • 9.98K
  • 292
  • 625
Hey there hildegunn,
Thanks for getting back to us Smiley Happy
Has changing the wireless channel helped?
As you don't have any means of testing the accurate speed via an Ethernet cable, we will have to just go through the wireless channels and find the best for your environment.
Hope to hear back from you soon,
Take care.
Heather_J
