  • 11
metaloona
Speed and IP issues total rubbish since said upgrade had enough
Been with Virginmedia / Telewest for years
our speed and router are rubbish
http://www.speedtest.net/my-result/6003298090
we are based in Essex and our IP shows Liverpool / Manchester ###########
I'm having to reboot the router near enough everyday
I'm actually connecting a brand new pc and using old pc and tablet and mobiles they all show the same results
The service is becoming unreliable
not happy am now considering leaving virginmedia full stop for all services
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 5.67K
  • 291
  • 1.25K
Re: Speed and IP issues total rubbish since said upgrade had enough
IP geolocations arn't really that great or trustable.
Takes a while for them to update when they change.
Mine hasn't change in quiet some years but i'm apparently based in Luton/Falkirk/Plymouth/Hook.
I live in Exeter so none of them are correct.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 11
metaloona
Thanks for the comment Shafreya
Yes I agree IP Locations aren't bang on full stop are they it also depends on what speed test your using
Think my issue is more todo with the said speed at least 70mb which we aren't getting
our average speed seems to be between 30mb up to 50mb and not the said speed boast 70mb +
I will state that the system I'm using is about the most up to date you can purchase is less than a month old and operates on 5G wifi
I also still have my old windows 10 system which I still use which operates on the older 2.4G system
Also use mobiles on indoor wifi they operate on 5G also
Have test Broadband speed on all equipment
What ever I've tested BB on still shows same results Speed issue?
I'm thinking it could possibly be the Super hub it's self or a wiring issue?
Because there have been a lot of faults in my area
And we have had times when we have had no Broadband at all due to repairs and maintenance
perhaps we should give tech a call to get them to investigate
