  • 5
Sideswipe
Message 1 of 8
Speed Upgrade
I'm just wondering how to find out when my speed upgrade is due. When I log into my account I get the following message:
I don't log into my account that often, but I seem to think the last time I looked the message said it was due in November 2016, but I've not noticed any speed increase.
  • 20.93K
  • 768
  • 1.56K
Message 2 of 8
Re: Speed Upgrade
Hi Sideswipe,
Thanks for your post Smiley Happy
Apologies for the delay with your free speed boost.
Have you checked the Speed upgrade website recently? If not have a look here: Speed Upgrade This will tell you when your area is due it's upgrade.
Keep us posted on this one.
Kath_F
  • 5
Sideswipe
Message 3 of 8
Re: Speed Upgrade
I've entered my postcode on the website and it says "Your speed boost is ready now", but I can't see any speed increase.
Do I need a different super hub for the new speed?
  • 5.33K
  • 269
  • 1.17K
Message 4 of 8
Re: Speed Upgrade
If you have a superhub2/2ac/3 then no you don't.
Might be worth calling up to get it processed or try a different web browser.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 5.33K
  • 269
  • 1.17K
Message 5 of 8
Re: Speed Upgrade
Will be quicker than going through the forum if it's ready. They can process it there and then via phone.
  • 26
cloverleaf146
Message 6 of 8
Re: Speed Upgrade
Have you changed your "package" recently ? If so, you are stuffed as far as the upgrade is concerned - it's a VM small print stitch up special.
  • 5
Sideswipe
Message 7 of 8
Re: Speed Upgrade
No I've not changed my package in years, but I do have only have a Superhub 1.0.
  • 5.33K
  • 269
  • 1.17K
Message 8 of 8
Re: Speed Upgrade
You will need a superhub2 or better at least. You will get told this while ordering, or through the order process.
