  • 7
john55501277
Message 1 of 5
Speed Upgrade And Upload Speed
If new customers join on 100mb, can you still do the free upgrade to 150mb, or is this no longer available?
On the new vivid 300 package, it doesn't mention unlimited uploads like the vivid 200 gamer package, is this a mistake, or is it just not unlimited uploads?
Did you get unlimited uploads on the homeworks 300 package?
http://www.virginmedia.com/shop/broadband/broadband-only.html
  • 22.27K
  • 852
  • 3.24K
Message 2 of 5
Re: Speed Upgrade And Upload Speed
no if you join now you will be on the upgraded speeds already.
  • 5.67K
  • 291
  • 1.25K
Message 3 of 5
And 300Mbs does not have Traffic management on the upload either. It is stated here:
https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030...
As its an upgrade to the gamer service, its implied it doesn't have traffic management as the gamer200 is the base package for it. Clarity would be a help though as you are not the first to ask.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 7
john55501277
Message 4 of 5
The upgrades were:
50/3 > 70/5
100/6 > 150/10
152/12 > 200/12
So if new customers join on the 100mb tier, will they be offered a free upgrade to 150mb?
  • 5.67K
  • 291
  • 1.25K
Message 5 of 5
To be eligible for those upgrades you had to be a customer from before October 2015.
Also you had to of not changed your contract since then either.
Any new customer from that time will not be offered the upgrade.
