shell04
Message 1 of 5
Speed Issues
Hi, I've been having speed problems for a while, but when I switched the hub over to 5ghz the speed shot up and I thought all my problems were over. However... I've now realised that a lot of my devices won't recognise 5ghz so I have to switch back. What else can I do?
  • 8
Disconectme
Message 2 of 5
Re: Speed Issues
My best advice would be to Change isp Smiley Happy
  • 7.58K
  • 188
  • 442
Message 3 of 5
Re: Speed Issues
Hi shell04 ,
Welcome to the forums, I am sorry to see you have been having trouble with your connection.
I have taken a look and things seem to be ok from this side.
You mention you have been having trouble with a wireless connection. Are you having the same trouble with a wired connection? Pop the Hub in to Modem only Mode with the computer in safe mode with networking. Let us know if this makes a difference.
If it is only the wireless you are having trouble with try Getting the best WiFi Signal
If you are having trouble with both it would be worth popping up a BQM as it will give us a better idea of what you are seeing from your side. (Please be aware link is external and we're not responsible for its contents).
Speak to you soon.
Emma
shell04
Message 4 of 5
Re: Speed Issues
Hi, thanks but I can't test it wired as my computer doesn't have an Ethernet port, and I don't have an adapter.
  • 10.59K
  • 311
  • 654
Message 5 of 5
Re: Speed Issues
Hello again shell04,
Thanks for a quick reply Smiley Happy
As we're unable to test your Ethernet connection, are you able to set up the BQM as Emma advised? We'll do our best to diagnose this as a wireless fault.
Speak with you again soon,
Take care.
Heather_J
