  • 171
  • 8
  • 14
Stealthbird97
Superfast
Message 1 of 30
Speed Issues...
I'm on the 150mb package, and I have only been getting 40mbs for the last 20 days....
I have tried the online chat, and phone. But neither have been able to help me.
I just made a post about this but for some reason the post was rejected. I would like to know why and I would like help with my internet connection.
Kind Regards
Cori
My Internet is worse than it was in 2013.
My Broadband Speed
I am pleased to announce I will be switching from VM.
I am not a VM employee. My IT knowledge is pretty good though.
If you find my answer useful, please sent Kudos. If I solve or answer your question, mark as helpful answer! Smiley Very Happy
  • 5.67K
  • 291
  • 1.25K
Message 2 of 30
Re: Speed Issues...
How are you testing? Wired or wirelessly?
40Mbs is a common wireless bottleneck.
Slow speeds all the time or just evenings?
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
  • 171
  • 8
  • 14
Stealthbird97
Superfast
Message 3 of 30
Re: Speed Issues...
However, t
Kind Regards
Cori
My Broadband Speed
  • 5.67K
  • 291
  • 1.25K
Message 4 of 30
Re: Speed Issues...
Phone staff literally can't do anything for a wired connection. They can just change your superhub wireless settings and reboot the hub.
What are your powerlevels like? Go to 192.168.0.1 / 192.168.100.1 in modem mode, don't log in, look for the router status button (top right for superhub 1/2, not sure where for superhub3 but you should be able to find it - if not you probably can find when signed in on it) - in the next menu go to the 'downstream' 'upstream' and 'network log' sections and copy and paste all the information from there to here, cover your IP in the network log if it shows up though.
Will see if anything obvious is there - admittedly I'm not hugely clued up on the network log but others on here may see / understand anything you may have popping up.
Also, if you haven't already, consider setting up a thinkbroadband quality monitor. Will show some other information on your connection too.
  • 171
  • 8
  • 14
Stealthbird97
Superfast
Message 5 of 30
Re: Speed Issues...
Thanks again for responding.
I will setup a Thinkboardband Quality Monitor, I used to have one, but I had problems with it not working correctly when I was using IPFIRE as a firewall.
I'll see it works with pfsense.
Here is the information from the superhub.
c677a77090
098317a9ac
First Time Last Time Priority Error Number Description
11/03/2017 17:15:54 GMT 11/03/2017 17:15:54 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Critical (3) 82000200 No Ranging Response received - T3 time-out
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
11/03/2017 17:14:23 GMT 11/03/2017 17:14:23 GMT Warning (5) 66050310 Auth Success - Web login successful.
11/03/2017 17:01:52 GMT 11/03/2017 17:01:52 GMT Error (4) 68010302 DHCP WAN IP - ###########
11/03/2017 17:01:09 GMT 11/03/2017 17:01:09 GMT Error (4) 68000407 TOD established
11/03/2017 16:50:39 GMT 11/03/2017 16:50:39 GMT Warning (5) 66050310 Auth Success - Web login successful.
11/03/2017 16:44:36 GMT 11/03/2017 16:44:36 GMT Error (4) 68010302 DHCP WAN IP - ##########
11/03/2017 16:43:52 GMT 11/03/2017 16:43:52 GMT Error (4) 68000407 TOD established
11/03/2017 16:42:15 GMT 11/03/2017 16:42:15 GMT Warning (5) 66050310 Auth Success - Web login successful.
11/03/2017 16:39:59 GMT 11/03/2017 16:39:59 GMT Error (4) 68000407 TOD established
11/03/2017 16:06:50 GMT 11/03/2017 16:06:50 GMT Error (4) 68000407 TOD established
11/03/2017 15:27:36 GMT 11/03/2017 15:27:36 GMT Error (4) 68000407 TOD established
11/03/2017 13:00:59 GMT 11/03/2017 13:00:59 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
08/03/2017 23:18:23 GMT 08/03/2017 23:18:23 GMT Error (4) 68000407 TOD established
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
Kind Regards
Cori
My Broadband Speed
  • 5.67K
  • 291
  • 1.25K
Message 6 of 30
Re: Speed Issues...
UPstream running too high at the very least, will flag this for a tech booking for you, forum team should hopefully be in contact tomorrow.
Edit out your IP from the network log, mods will be gone by now to remove it themselves.
  • 171
  • 8
  • 14
Stealthbird97
Superfast
Message 7 of 30
Re: Speed Issues...
For some reason the edit post option has disappeared.
I didn't remove that IP's that are there as I didn't believe they were mine. I think that might have been from when I was in normal mode.
In modem mode now. and the IP's listed are not my ip currently.
Kind Regards
Cori
My Broadband Speed
  • 171
  • 8
  • 14
Stealthbird97
Superfast
Message 8 of 30
Re: Speed Issues...
It's now 00:30 on monday. More than 24 hours later, and my speed is still as bad as it was before.
Will be phoning up again today and hopefully I will get through to an English callcentre...
Kind Regards
Cori
My Broadband Speed
  • 5.67K
  • 291
  • 1.25K
Message 9 of 30
Re: Speed Issues...
Go for the 'thinking of leaving us' option during office hours and you should get U.K. based agents.
  • 10.82K
  • 308
  • 632
Message 10 of 30
Re: Speed Issues...
Hi there Stealthbird97,
Thanks for taking the time to post on the community.
Sorry to see you are having an issue with your broadband connection.
I've just checked your connection and the upstream power levels are now within range at 48 dBmV, which is good. I did notice an issue with high traffic on the network that I have raised to our networks department for further investigation.
It may also be worth you taking a look at this link > Traffic Management.
Will speak to you soon
Sam
