RWLValo
Just joined
Speed Drop & Connectivity Issues
Having some major issues with my connectivity, having big speed drop offs regularly to the point where a simple website won't load all the way to losing connection entirely. Here's the status report from the Modem GUI.
Cable Modem Status Item Status Comments
Acquired Downstream Channel (Hz) 218750000 Locked
Ranged Upstream Channel (Hz) 39400000 Success
Provisioning State OK Operational
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 218750000 226750000 234750000 242750000 250750000 258750000 266750000 274750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 7 8 9 10 11 12 13 14
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV) 4.29 4.17 4.55 3.59 4.78 4.84 4.44 4.57
RxMER (dB) 36.61 36.61 36.17 35.97 36.84 36.39 0.00 36.17
Pre RS Errors 10967 11350 11389 12268 10839 11079 0 11447
Post RS Errors 7873 8286 8573 9097 7998 8108 0 8473
Upstream   US-1 US-2 US-3 US-4
Channel Type 2.0 N/A N/A 2.0
Channel ID 50 N/A N/A 52
Frequency (Hz) 39400000 N/A N/A 25800000
Ranging Status Success Other Other Success
Modulation 64QAM N/A N/A 64QAM
Symbol Rate (Sym/sec) 5120000 N/A N/A 5120000
Mini-Slot Size 4 N/A N/A 4
Power Level (dBmV) 42.25 N/A N/A 40.25
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 2 0 0 1
T4 Timeouts 0 0 0 0
First Time Last Time Priority Error Number Description
03/02/2017 13:58:14 GMT 03/02/2017 13:58:14 GMT Error (4) 68000410 TOD resynchronisation failure
03/02/2017 04:45:38 GMT 03/02/2017 04:45:38 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
03/02/2017 03:40:06 GMT 03/02/2017 03:40:06 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
01/02/2017 14:06:01 GMT 01/02/2017 14:06:01 GMT Warning (5) 84020200 Lost MDD Timeout
01/02/2017 14:06:00 GMT 01/02/2017 14:06:00 GMT Warning (5) 84020200 Lost MDD Timeout
01/02/2017 14:05:55 GMT 01/02/2017 14:05:55 GMT Critical (3) 84000500 SYNC Timing Synchronization failure - Loss of Sync
01/02/2017 13:25:57 GMT 01/02/2017 13:25:57 GMT Error (4) 68010302 DHCP WAN IP - 86.4.*******
01/02/2017 13:25:22 GMT 01/02/2017 13:25:22 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
01/02/2017 13:25:17 GMT 01/02/2017 13:25:17 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
Time Not Established Time Not Established Error (4) 68000409 TOD not Established
01/02/2017 12:28:55 GMT 01/02/2017 12:28:55 GMT Error (4) 68000409 TOD not Established
01/02/2017 12:28:34 GMT 01/02/2017 12:28:34 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Thank you to anyone able to help me with this issue!
[MOD EDIT: For your security personal and private information has been removed from this post. Please review the Forum Guidelines]
  • 90
maxmarutti
Re: Speed Drop & Connectivity Issues
just check here -> post RS errors
@thinkbroadband
  • 7.57K
  • 188
  • 441
Hi RWLValo,
Welcome to the forums, I am sorry to see you have been having trouble with your connection.
I have taken a look and things seem to be ok from this side.
I notice there are some Post RS errors on the stats you posted up, do they continue to climb once you reset them?
If so can you reset the Post RS errors and then post another shot of the stats up for me please?
Keep me posted.
Emma
