  • 242
  • 47
LokiDog
Superfast
Speed Boost, how to get it....
https://keepup.virginmedia.com/speedupgrade says it's ready.
I log in and see this:
Hold on tight. Your speed boost is on the way…
Your speed upgrade will be ready to take your connection from up to 50Mbps to up to 70Mbps. It's all thanks to DOCSIS® - the magic in our cables. Look out for it between January 2017 and January 2017
How the hell do I get it?
  • 242
  • 47
LokiDog
Superfast
Re: Speed Boost, how to get it....
 **bleep**???????????
  • 896
  • 18
  • 323
pete7049
Well-informed
Mine got pushed back yesterday from Feb' to May-July. Another case of VM's wonderful efficiency. Smiley Happy
F003443743. December '14 - May '17.
  • 242
  • 47
LokiDog
Superfast
If you look at the image I posted you will notice mine has been 'pulled back' to 2015 not pushed forward
