  • 6
Andrew_Cook
Message 1 of 9
Sort your connection out!
Over the past 2 days, my internet has been messing up! I am a YouTuber, who plays Minecraft. But unfortunately, your connections are not good. Every 10 seconds i lagg. Then i disconnect from the game because of your crappy connections! I have even tried to reset my router but its not the routers problem! Please sort this out immediately or I will switch to another supplier!!
Your connections used to be good. Now i'm starting to doubt it!
  • 6
Andrew_Cook
Message 2 of 9
Re: Sort your connection out!
  • 15
ianchapple13
Message 3 of 9
Are you in area 24 by any chance ?
  • 16.5K
  • 1.38K
  • 3.37K
Message 4 of 9
hiya @Andrew_Cook there is currently around a weeks wait for the forum admin to reply and check your connection in the mean time Would need to check the signal levels if could go to http://192.168.0.1 clicking router status top right [no need to login] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it.. also how are you connecting wired/wireless?
if its via wireless can you test it via wired
  • 6
Andrew_Cook
Message 5 of 9
Downstream bonded channels Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
1139000000435.7256 qam1
23230000003.537.3256 qam24
33150000004.137.3256 qam23
43070000003.937.6256 qam22
52990000003.737.3256 qam21
62910000004.537.3256 qam20
72830000003.937.3256 qam19
8275000000437.6256 qam18
92670000005.437.6256 qam17
102590000004.537.6256 qam16
112510000003.737.3256 qam15
12243000000437.6256 qam14
132350000004.937.3256 qam13
14227000000536.6256 qam12
152190000005.434.9256 qam11
162110000005.137.6256 qam10
172030000005.537.3256 qam9
18195000000637.3256 qam8
191870000005.836.6256 qam7
201790000005.537.3256 qam6
21171000000737.3256 qam5
221630000005.636.6256 qam4
231550000006.136.6256 qam3
241470000002.235.7256 qam2
Upstream bonded channelsChannel IDFrequency(Hz)ModePower
(dBmV)ModulationChannel Bandwidth(Hz)Symbol Rate (ksps)146200000ATDMA4516 qam64000005120239400000ATDMA4516 qam64000005120
Network Log Date And Time Error Number Event Description
2017-09-13 20:34:08.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-13 20:35:08.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:23.0084020100Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-13 20:57:59.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-13 22:14:03.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-13 22:16:23.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-13 23:30:36.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-13 23:30:43.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 01:42:24.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 01:43:03.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 07:51:49.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 07:52:24.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 09:16:01.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 09:18:12.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 13:41:38.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 13:41:53.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 17:49:58.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 17:52:45.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 19:04:34.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-09-14 19:05:05.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 6
Andrew_Cook
Message 6 of 9
I have a TP-LINK to boost speeds. I dont know how to connect to the internet without it lol
  • 6
Andrew_Cook
Message 7 of 9
This is getting beyond the joke now, I Phoned up today. Won't be fixed until December time! Area 30! Come on!
We are now switching to Sky Broadband. Get rid of this crappy provider.
  • 6
Andrew_Cook
Message 8 of 9
I honestly don't know why people still use this **bleep**ty ISP, It's a joke! It's probably better without WIFI.
  • 14
MavN81
Message 9 of 9
 Good luck because you will need it with Sky as their BB is awful for gaming!
