Rkjsurg
Snail speed broadband
Just signed up for 100mb broadband and consistently getting 20-30 mb even in quiet times
Very annoying
  • 9.35K
  • 797
  • 1.96K
Re: Snail speed broadband
How are you connecting wired or wirelessly?
If wireless, try wired directly to the hub
Rkjsurg
Wireless with latest virgin hub/router
Will try wired
What in your opinion is reasonable speed wirelessly with 100mb package. I have not seen any improvement at all from 20mb package
  • 8.32K
  • 357
  • 586
Hi Rkjsurg,
Welcome to the Community!
Sorry to hear you've been having speed issues.
Have you managed to test a wired connection?
Also, it's difficult to say what a reasonable speed would be on wireless as there are so many environmental factors that can negatively influence the signal. If you prefer to connect wirelessly, there are a few things you can do to make sure you're getting the best out of your wireless connection. You can also try changing your hub's wireless channel to find the least congested signal.
Hope this helps! Smiley Very Happy
Josh
