  • 9
browncoat
Message 1 of 12
Slow with latency issues: 200Mb in NW6
I recently upgraded to the 200Mb service and Hub 3.0 and thing seem to be slower. I'm running the Hub in modem mode. Even on a wired connection, I can experience buffering on Youtube (seems to be quite common on Virgin from what I've read) and occasional issues with Netflix and Amazon Video. Latency can be a real issue, with browsers waiting some time before loading the webpage. Surprisingly downloads can be quite speedy although not significantly better than my previous 100Mb connection.
Router status is below. Any help would be appreciated!
Router info:
Date And Time
Error Number
Event Description
2016-08-20 16:58:03.00
68010400
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
68010600
DHCP Renew - lease parameters tftp file-V0dea97109ea7aa00.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-22 21:48:05.00
82000200
2016-08-25 06:14:22.00
68010100
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-08-30 14:10:00.00
68010400
68010600
2016-09-03 20:11:18.00
68010100
2016-09-05 00:00:50.00
68010400
68010600
2016-09-05 23:55:47.00
69010100
SW Download INIT - Via NMS
2016-09-06 00:07:41.00
69011100
SW download Successful - Via NMS
2016-09-08 12:43:16.00
82000200
2016-09-10 19:39:51.00
68010100
2016-09-12 03:09:54.00
68010400
68010600
2016-09-15 03:21:07.00
68010100
2016-09-15 23:02:26.00
68010400
68010600
2016-09-18 03:18:19.00
82000200
2016-09-19 21:05:38.00
83000114
Service Add rejected - Duplicated reference-ID or index in message;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Operational Configuration
General Configuration
Value
Network access
Enabled
Maximum Number of CPEs
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
87dsfd;kfoA,.iyewrkl
SFID
12287
Max Traffic Rate
220000000
Primary Upstream Service Flow
SFID
12286
Max Traffic Rate
12700000
Channel
Frequency(Hz)
Power
(dBmV)
SNR
(dB)
Modulation
Channel ID
1
299000000
5.5
33
256 qam
55
2
307000000
5.5
33
256 qam
56
3
291000000
5
33
256 qam
54
4
283000000
4.8
33
256 qam
53
5
275000000
4.8
33.3
256 qam
52
6
267000000
5
33.3
256 qam
51
7
259000000
5.4
33.3
256 qam
50
8
251000000
5.5
33.4
256 qam
49
Channel ID
Frequency(Hz)
Mode
Power
(dBmV)
Modulation
Channel Bandwidth(Hz)
Symbol Rate (ksps)
5
39400000
ATDMA
42.3
16 qam
6400000
5120
4
46200000
ATDMA
42.3
16 qam
6400000
5120
Helpful Answers
  • 1.62K
  • 145
  • 439
Message 4 of 12
Re: Slow with latency issues: 200Mb in NW6
SNR is too low. Forum staff are taking up to 2 weeks to reply at the moment, probably best to phone in. Early morning is best to avoid off shore and to speak to someone who has a clue.
All Replies
  • 9
browncoat
Message 2 of 12
any help from Customer service would be appreciated.
Main issues are time waiting for websites to load, ping times and slow speed test results.
  • 9
browncoat
Message 3 of 12
No one has any ideas? I'm happy to post further modem info.
  • 1.62K
  • 145
  • 439
Message 4 of 12
  • 9
browncoat
Message 5 of 12
Thanks for the advice. Now to find time to call.
  • 10.82K
  • 308
  • 631
Message 6 of 12
Hi browncoat
Thanks for posting back on the community.
My apologies that you are experiencing issues with your broadband connection.
As HiVMBye mentioned the Modem SNR (signal to noise ratio) is running low and I can arrange an engineer appointment for you, to check this over. I've sent you a PM (purple envelope icon, right corner) with some details for you to confirm please. Once you have replied I can go ahead with the appointment.
Hope to hear from you soon
Sam
  • 9
browncoat
Message 7 of 12
Thanks Sam,
I replied to your PM.
Niraj
  • 9
panorama93
Message 8 of 12
Too many concurrent users online in NW6, especially on Saturday & Sunday.  The local cable network needs a massive upgrade.  I am typing this using my neighbour's free BT WiFi hotspot.  Maybe time to find better broadband provider...
  • 9
panorama93
Message 9 of 12
Further to my previous reply just to update that minutes after posting it, surprise surprise, my broadband leapt into life on both wired and wireless after being continuously down or slow for about 6 hours today. Seems that perhaps someone reads my post and then flicks a switch somewhere...!
  • 9
browncoat
Message 10 of 12
Quick update:
An engineer visited and confirmed there were no SNR issues. He replaced the Hub 3.0. On router mode it seemed fine but on switching to modem mode everything started crawling again. I spoke to 150 and they recommended a Hub 2+ (2ac) router. Modem mode remained slow. I have since switched the router back to router mode and initially speed was excellent.
Tonight download <10Mbs with stuttering iplayer. I think a new broadband provider maybe required....
