  • 6
mwkenna
Message 1 of 7
Slow wired speed
I supposedly have a 200Mb/s service. PC is running a gigabit card however the maximum speed I ever obtain from the various speed testers is 68.23 Mb/s. Note that this is a wired connection not WIFI. Anyone have any ideas? Is this normal to get roughly 1/4 of what you are paying for?
Mark.
  • 7
calvin646
Message 2 of 7
Re: Slow wired speed
your lucky your getting a 1/4 mate im lucky if i get 10% in non peak hours on a 100mbts package i get same excuses over utilisation which is basically they cant provide what you pay extra for and its not even fibre optic were getting as fibre is only run to telephone exchanges its copper cable to your house  same an last 30 years pretty much
  • 9.34K
  • 797
  • 1.96K
Message 3 of 7
mwkenna wrote:
Mark.
Posting some basic diagnostic info may help.
Navigate to the hub's GUI using http://192.168.100.1
Don't log in, click the Router Status button in the top right of the screen.
Copy \ Paste the Downstream, Upstream, and Network Logs.
Don't worry about the formatting.
Are you experiencing slow wired speeds all the time or only during peak evening periods?
  • 6
mwkenna
Message 4 of 7
Here you go:
Downstream
DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 267000000 235000000 243000000 251000000 259000000 275000000 283000000 291000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 29 25 26 27 28 30 31 32
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) -3.21 -2.22 -2.48 -2.47 -2.62 -3.61 -4.12 -4.22
RxMER (dB) 37.94 37.94 37.94 37.94 38.61 37.94 37.36 37.64
Pre RS Errors Reset Counter 3040 13836 2512 1523 296 915 282 293
Post RS Errors Reset Counter 309 283 298 281 289 906 275 288
Upstream
US-1 US-2 US-3 US-4
Channel Type 2.0 N/A N/A 2.0
Channel ID 19 N/A N/A 17
Frequency (Hz) 32600000 N/A N/A 46200000
Ranging Status Success Other Other Success
Modulation 16QAM N/A N/A 16QAM
Symbol Rate (Sym/sec) 5120000 N/A N/A 5120000
Mini-Slot Size 4 N/A N/A 4
Power Level (dBmV) 41.50 N/A N/A 42.25
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 1 0 0 0
T4 Timeouts 0 0 0 0
First Time Last Time Priority Error Number Description
08/01/2017 18:32:37 GMT 08/01/2017 18:32:37 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/01/2017 18:04:17 GMT 08/01/2017 18:04:17 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/01/2017 18:01:06 GMT 08/01/2017 18:01:06 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/01/2017 09:48:13 GMT 08/01/2017 09:48:13 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/01/2017 09:48:06 GMT 08/01/2017 09:48:06 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/01/2017 09:08:42 GMT 08/01/2017 09:08:42 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/01/2017 08:55:45 GMT 08/01/2017 08:55:45 GMT Warning (5) 66050310 Auth Success - Web login successful.
07/01/2017 22:55:13 GMT 07/01/2017 22:55:13 GMT Error (4) 68010302 DHCP WAN IP - removed
07/01/2017 22:54:11 GMT 07/01/2017 22:54:11 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Critical (3) 82000200 No Ranging Response received - T3 time-out
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
07/01/2017 18:30:39 GMT 07/01/2017 18:30:39 GMT Error (4) 68010302 DHCP WAN IP - removed
07/01/2017 18:29:38 GMT 07/01/2017 18:29:38 GMT Error (4) 68000407 TOD established
06/01/2017 18:15:12 GMT 06/01/2017 18:15:12 GMT Warning (5) 66050310 Auth Success - Web login successful.
06/01/2017 18:15:04 GMT 06/01/2017 18:15:04 GMT Warning (5) 66050310 Auth Success - Web login successful.
04/01/2017 14:54:51 GMT 04/01/2017 14:54:51 GMT Error (4) 68010400 DHCP REBIND WARNING - Field invalid in response
04/01/2017 14:54:05 GMT 04/01/2017 14:54:05 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
04/01/2017 14:53:22 GMT 04/01/2017 14:53:22 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
Mark.
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 6
mwkenna
Message 5 of 7
Forgot to mention, the speed is pretty much the same all the time. I have not noticed a change in speed from the jump to 200Mbps from 100Mbps.
  • 9.34K
  • 797
  • 1.96K
Message 6 of 7
Power levels and SNR look fine and there is nothing obvious in the logs to show why you are getting slow speeds.
It might be worth trying another ethernet cable ensuring it is CAT 5E spec or better.
I would check that the ethernet adapter's drivers are up to date according to the adapter's manufacturer's website (Do not rely on Windows Update)
Then I would check the speed with the Hub in Modem mode, remembering you will need to access the hub using 192.168.100.1 in modem mode.
It might be a good idea to start a Broadband Quality Monitor here. You will need to enable Respond to ICMP Echo Requests in the advanced setion of the Hub's GUI or disable the firewall if you have a hub 3
  • 13.15K
  • 376
  • 1.08K
Moderator
Moderator
Message 7 of 7
Hi mwkenna,
Just to add to griffins advice, I've run a few checks on your service from this end and all looks in good shape, so headline speeds should be very achievable.
A quick test in modem mode may be a thought too, keep us posted Smiley Happy
Ralph_R
Forum Moderator
