  • 41
Slotcar
Message 1 of 86
Slow speed/constant disconnects derby Area 20
My broardband goes very slow at about 4:00pm till gone 11:00pm
here is a link to my speedtest page
http://www.speedtest.net/results.php?sh=2271f806b2858fed1de993a14abe5c0d&ria=0
  • 16.71K
  • 1.4K
  • 3.43K
Message 2 of 86
Re: Slow speed/constant disconnects derby Area 20
possible cause could be high network traffic/util, with your connection is this wired/wireless.. If its wireless can you test the speed on a wired connection. When your having the slow connection
  • 41
Slotcar
Message 3 of 86
Makes no difference which and there are tests which not complete.
And here is my Broadband Quality Monitor
http://www.thinkbroadband.com/ping/share-thumb/422a337969a6e97bc5c187eb5dfb477e-10-03-2014.png
  • 41
Slotcar
Message 4 of 86
  • 12.67K
  • 359
  • 1.47K
Message 5 of 86
Hi Slotcar,
Apologies for the reduced speeds you've been experiencing. I think that utilisation is the main cause as we already have this under investigation, ref: F002240686.
Some work has already been done (the implementation of additional upstreams) with the remainder of the upgrade work currently on target for mid April.
The estimated fix dates are estimated though and may change so do request updates on here and we'll re-check that for you.
Whilst this is ongoing you can request a month-by-month credit by calling Customer Services on 150 (from a Virgin landline) or 0845 454 1111 (from any other phone).
Best wishes,
Jen
Jen
  • 41
Slotcar
Message 6 of 86
one of the better tests for this time of night
http://www.thinkbroadband.com/speedtest/results.html?id=139569442476144287724
have a new modem coming on Wednesday will see how we get on.
RelRelRel
Message 7 of 86
I'm also in Derby, and this isn't dissimilar to what i'm experiencing.
http://community.virginmedia.com/t5/Up-to-30Mb-Speed/Service-getting-worse-last-few-months/td-p/2240...
  • 7.79K
  • 190
  • 448
Message 8 of 86
Hi RelRelRel,
Thanks for getting in touch, I've had a look at your connection and it seems you're affected by F002986451 Utilisation.
Due to the complex nature of these faults I do not currently have a resolve date for you but we should have an update on this after 23/04/2014. Please give this thread a bump after this time and we'll happily get an update for you.
Your modem is showing as offline at the moment so I'm unable to check if there is any other issues with your connection. Apologies for this.
It may be worth giving this a try http://virg.co/bbtips to get things moving.
Let us know how you get on
Thank you
Emma
  • 41
Slotcar
Message 9 of 86
speeds have gone down again
First TimeLast TimePriorityError NumberDescription
04/08/2014 18:53:01 GMT04/08/2014 18:53:01 GMTWarning (5)66050300Auth Fail - Web login failed.
04/08/2014 18:38:44 GMT04/08/2014 18:38:44 GMTWarning (5)66050310Auth Success - Web login successful.
04/08/2014 18:31:28 GMT04/08/2014 18:31:28 GMTWarning (5)66050310Auth Success - Web login successful.
04/08/2014 18:30:22 GMT04/08/2014 18:30:22 GMTError (4)68010302DHCP WAN IP - 80.1.101.179
04/08/2014 18:29:24 GMT04/08/2014 18:29:24 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
04/08/2014 12:28:10 GMT04/08/2014 12:28:10 GMTError (4)68010400DHCP REBIND WARNING - Field invalid in response
04/08/2014 12:27:12 GMT04/08/2014 12:27:12 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
04/08/2014 12:26:17 GMT04/08/2014 12:26:17 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
04/08/2014 12:24:27 GMT04/08/2014 12:24:27 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
04/08/2014 12:20:46 GMT04/08/2014 12:20:46 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
04/08/2014 12:13:23 GMT04/08/2014 12:13:23 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
04/08/2014 11:58:37 GMT04/08/2014 11:58:37 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
04/08/2014 11:50:37 GMT04/08/2014 11:50:37 GMTCritical (3)82000200No Ranging Response received - T3 time-out
04/08/2014 11:50:36 GMT04/08/2014 11:50:36 GMTCritical (3)82000200No Ranging Response received - T3 time-out
04/08/2014 11:50:35 GMT04/08/2014 11:50:35 GMTCritical (3)82000200No Ranging Response received - T3 time-out
04/08/2014 11:50:34 GMT04/08/2014 11:50:34 GMTCritical (3)82000200No Ranging Response received - T3 time-out
04/08/2014 11:50:32 GMT04/08/2014 11:50:32 GMTCritical (3)82000200No Ranging Response received - T3 time-out
04/08/2014 11:50:29 GMT04/08/2014 11:50:29 GMTWarning (5)84020200Lost MDD Timeout
  • 13.26K
  • 381
  • 1.09K
Moderator
Moderator
Message 10 of 86
Hi slotcar,
Apologies for the ongoing problems, checking high utilisation ticket F002240686 I can see that the estimated date for upgrade works to resolve this is currently October.
Sorry again for the inconvenience caused, please continue to bump us here periodically and we'll gladly check for any news.
Ralph_R
Forum Moderator
