creepstein
Slow speed/High Ping in NR2 Region
I have been using a 100mbps plan on virgin media for a year before they upgrade it to 150mbps.
During the past few days (2-3 days) i noticed a speed drop in the internet connection and my house mates confirms this. Also, using sites like speedtest.net, we have been getting high pings using local servers, pings averaging between 200-500. Is the an issue going on in the NR2 region? I have done the service status tests which asks me to reset the modem after 10 minutes but it doesnt seem to have helped.
Regards,
Caleb
Helpful Answers
  • 13.02K
  • 372
  • 1.06K
Moderator
Moderator
Re: Slow speed/High Ping in NR2 Region
Hi Caleb,
Thanks for getting in touch, I've run a few checks on your service from this end and looks like your Hubs downstream power levels may be the issue, running a bit on the high side, we can fix this with an engineer visit. I'll drop you a PM so we can this booked in for you.
Cheers
Ralph_R
Forum Moderator
All Replies
  • 13.02K
  • 372
  • 1.06K
Moderator
Moderator
Hi Caleb,
Cheers
Ralph_R
Forum Moderator
