  • 48
Nocky24
Message 1 of 15
Slow download speed - WS10 area
Experiencing very slow speeds on your wals11-2-0 uBR and have been for a number of days now during peak times (e.g. 6pm-11pm). I suspect it's congestion (almost always is). Are you able to check this mods?
Stats are as follows, which having done some reading look like they're within parameters:
Upload is perfectly fine as you can see.
Question: I'm using a SuperHub 2 which looks like it's capped at 8 bonded channels. Will a SuperHub 3 allow for more channels? I'm guessing it depends on what my cmts supplies, but I wondered if there was a modem limitation at the consumer end.
Cheers, Rich
  • 48
Nocky24
Message 2 of 15
Re: Slow download speed - WS10 area
Managed to speak to someone from support and they quoted fault ref F004902025 as the likely cause with an estimated fix date of 07/12/2016. I'll likely follow this up if it isn't fixed by then.
By the way I'm on the 100mb package. Just tried to do another speedtest and it failed to complete it and stuck at 0.52Mbps down - I feel like I'm slowly drifting back in time Smiley Happy
These are wired tests with no issues on my internal network (I help maintain a corporate network so I think I've got this bit right).
  • 10.69K
  • 314
  • 657
Message 3 of 15
Hello Nocky24,
Thanks for getting in touch Smiley Happy
How is your connection at the moment? Do you have anything new to report?
Please get back to us so we can continue to investigate.
Catch you soon,
Take care.
Heather_J
  • 48
Nocky24
Message 4 of 15
Hi here's a speed test I've taken just this second:
Looks like it's still an issue and I suspect my area is oversubscribed again. Can you investigate and come back to me please?
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 48
Nocky24
Message 5 of 15
Tried calling your support line on two occasions now and on both occasions the call has been dropped after 10 minutes.
Really hope I don't need to contact your CEO department again to get some traction on this....
  • 10.82K
  • 308
  • 632
Message 6 of 15
Hi there Nocky24,
Thanks for getting back to us.
I've taken a look at the network and there is a high peak time traffic fault raised in your area. The reference number is F004227847 and has a review date of 18th January 2017.
I'm sorry for the delay and inconvenience caused.
Sam
  • 48
Nocky24
Message 7 of 15
Thanks for the update Sam, much appreciated.
  • 48
Nocky24
Message 8 of 15
Any update on this? It seems better, but it isn't anywhere near 100mb.
  • 8.36K
  • 362
  • 589
Message 9 of 15
Hi Nocky,
Thanks for posting!
Glad to hear it's sped up a bit. I've checked the network and the current review date is set to 12th April.
Sorry again for the trouble.
Josh
  • 48
Nocky24
Message 10 of 15
Thanks for the update Josh
