Terrel
Slow broadband
My broadband is slow it was activated today I am using a ethernet cable.
Is my stats in range?:
Channel Frequency(Hz)
Power (dBmV) SNR (dB) Modulation Channel ID
1 402750000 1.9 40.3 256 qam 7
Channel ID Frequency(Hz) Modulation Power
(dBmV) Mode Channel Bandwidth(Hz) Symbol Rate (ksps)
1 19800000 TDMA 38 QPSK 1600000 1280
  • 542
  • 41
  • 84
DavidJWalker
Rising star
Re: Slow broadband
during peek hours thats weekends and 4pm to midnight you will get slow speeds due to over utilisation issues across the network everyone is getting slow speed
thats incl me getting slow speed
Using VIVID 350 Optical Fibre, Player TV, Talk Weekends
Just another VM user trying to help out so my answers may be wrong.
If you do like my answer please mark it as helpful; it may help others
Terrel
Re: Slow broadband
  • 8.99K
  • 756
  • 1.88K
Re: Slow broadband
Can you please post the Downstream and Upstream power levels and Network logs in full please, snippets do not give the full picture.
Terrel
Re: Slow broadband
Date And TimeError NumberEvent Description2016-11-25 10:07:19.0069010200SW Download INIT - Via Config file2016-11-25 10:11:37.0069011200SW download Successful - Via Config file1970-01-01 00:01:38.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2016-11-25 10:17:42.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2016-11-25 10:17:42.0084000700RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;1970-01-01 00:01:32.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;1970-01-01 00:01:32.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2016-12-10 11:11:43.0069020600Improper Configuration File CVC Format2016-12-10 11:11:43.0069020700Configuration File CVC Validation Failure2016-12-10 11:19:37.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.0;CM-VER=3.0;2016-12-10 11:19:57.0082000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.0;CM-VER=3.0;2016-12-10 11:22:10.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2016-12-10 11:22:10.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2016-12-10 11:22:35.0069020600Improper Configuration File CVC Format2016-12-10 11:22:35.0069020700Configuration File CVC Validation Failure1970-01-01 00:01:27.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;1970-01-01 00:01:27.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;1970-01-01 00:01:29.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;1970-01-01 00:01:29.0084020300MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;2016-12-10 12:22:24.0084000500SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.0;CM-VER=3.0;
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Re: Slow broadband
Hi Terrel,
Thanks for the post! I am sorry to hear about your issues with slow speeds, I apologise for any inconvenience caused.
I have tested things from here, and I can see a number of time outs inside your Hubs logs, I would like to arrange for an engineer to attend in order to resolve this for you.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with making the booking, please respond to me there and I'll get this sorted for you.
Take care,
Adam.
