  • 14
Ajb1975
Slow broadband
 I'm paying for 150 Mbps and this is what I'm actually getting 😡
  • 2.96K
  • 378
  • 939
Re: Slow broadband
Are you testing using a wired Ethernet connection to the VM hub or a wireless connection? Wireless is easily disrupted by a number of external factors, so a wired test is the best way to get a true picture of what speed your line is able to achieve. It also helps to pinpoint if the issue is with the wireless or your line.
Are you seeing slow speeds all day or only at peak times (typically 4pm-11pm weekdays and weekends)? Some areas are suffering with over utilisation, which results in very slow speeds at peak times but full speed at off peak times.
If wired off peak tests show slow speeds then some hub stats might help.  Go to http://192.168.100.1/ to get the VM hub GUI. Don't login but instead click on Router Status which is either a button in the top right of the screen or a text link at the bottom of the screen depending on which hub you have. Click on the Downstream, Upstream and Network Log sections and copy & paste the figures from those screens and post them here, don't worry about the formatting or you can post screenshots if that is easier. Be careful to edit out or obscure any reference to your WAN IP in the log to protect your privacy.
The community can have a look for you and see if anything in the figures looks wrong and advise accordingly. Or you can wait for the VM staff to pick up this thread (can take up to a week) and run checks on your line.
______________________
Scott
  • 5.98K
  • 159
  • 415
Re: Slow broadband
Hi there Ajb1975,
Really sorry to hear about the connection fault experienced.
I've located your account and I can see that the equipment is currently showing as offline.
Has this been turned off manually? If so, could you reboot this for me to take a look at the equipment levels for you.
Speak soon,
Nat_J
