ktron
Message 1 of 11
Slow broadband speed
I signed up for vivid 200 and have noticed I get no where near that speed ever.
This is an example of my average speed - I have tested this on and off over a number of days at different times of the day and night.
I am doing this wireless with a 802.11ac adapter with a full bar of signal strength.
I am in area 24.
Any help appreciated.
Kevin
  • 5.63K
  • 287
  • 1.24K
Message 2 of 11
Re: Slow broadband speed
You will need to reupload the speed test picture, but make sure you cover your IP up before doing so.
Speedresult was:
Ping: 12Ms
Download 18.70Mbs
Upload 12.50Mbs
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
ktron
Message 3 of 11
OK...lets try again. At 10.50pm....speed is now down to 15.36. This on a 200 Mbps service.
  • 90
maxmarutti
Message 4 of 11
cover your IP mate ;-)
@thinkbroadband
  • 90
maxmarutti
Message 5 of 11
Run your test here -> test  Robot wink
Or here dslreport test
@thinkbroadband
ktron
Message 6 of 11
Ok..lets use those sites
I would be happy to get over 100, but low 20's at 7.30 in the morning and Im paying for 200 Mbps!
  • 90
maxmarutti
Message 7 of 11
Send me your data/speed test  picture address on PM I paste it here for you
P.S check your email box right up corner -- Purple Envelope, top right hand corner.
Max
@thinkbroadband
  • 90
maxmarutti
Message 8 of 11
ktron's speed test screenshot
All done ktron
Best Regards
max
@thinkbroadband
  • 90
maxmarutti
Message 9 of 11
ktron wrote:
I am in area 24.
Kevin
Kevin could you paste more stats , network logs , upstream/downstream logs please [see pictures]
Type in web browser 192.168.100.1  then follow the pics
@thinkbroadband
ktron
Message 10 of 11
Hi Max
Cannot see your pics for some reason (yellow triangle).
However here is some info from logs
Downstream
Channel Frequency(Hz) Power
(dBmV) SNR
(dB) Modulation Channel ID
1299000000538.9256 qam33
23230000004.938.6256 qam36
33150000004.638.9256 qam35
43070000004.838.6256 qam34
5291000000538.6256 qam32
62830000004.538.6256 qam31
72750000004.538.6256 qam30
82670000004.638.6256 qam29
92590000004.938.6256 qam28
102510000005.338.6256 qam27
112430000005.538.6256 qam26
12235000000538.6256 qam25
upstream
Channel ID Frequency(Hz) Mode Power
5839400000ATDMA4364 qam64000005120
5932600000ATDMA4364 qam64000005120
Network logs
Date And Time Error Number Event Description
2016-12-22 14:09:01.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-23 08:14:58.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-27 22:36:11.0084020200Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-28 03:26:05.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-28 14:14:40.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-28 19:08:31.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-29 10:51:01.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-30 06:38:19.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-01 11:18:45.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-02 07:04:34.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-06 20:55:16.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-12 04:28:50.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-18 08:22:32.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-20 12:21:19.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-21 19:37:49.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-24 20:32:36.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-25 16:25:48.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-01-26 10:23:20.0082000200No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-01 11:10:50.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2017-02-02 18:13:35.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Thanks in advance.
