  • 5
Raxsah
Slow broadband speed and T4 timeouts
Hi all
So this evening I've been getting some fluctuating download speeds, between 9mbps and 15mbps, through ethernet. My normal speed is closer to 50mbps according to speedtest.net! I've rebooted the router and had a check through my routers network log (screenshot included)
Problem is, I have no idea what these time outs mean.  Is there anything I can do to try and resolve this issue myself?  Hopefully it resolves itself by tomorrow but if not I'd like to know my best course of action Smiley Happy
Oh, my ping is fine too! Ranges between 9ms & 15ms
Thanks in advance!
Rax
  • 6.77K
  • 273
  • 491
Re: Slow broadband speed and T4 timeouts
Hi Raxsah,
Thanks for posting!
Sorry to hear you've had trouble with your connection.
I've run diagnostics on your equipment and everything is looking okay at the moment. Are you still experiencing issues?
Speak soon Smiley Very Happy
Josh
  • 5
Raxsah
Hi Josh
Everything seemed to sort itself a few hours later, thankfully!
It was just very strange as I've never encountered a T4 timeout before so I panicked - last time I had problems with my router I ended up phoning up and getting a technician out who replaced the router entirely!
Thank you for replying and having a look!  Is there anything I can do if it happens again or just wait?
All the best
Rax
  • 9.61K
  • 284
  • 614
Hey Rax,
Thanks for the update Smiley Happy
Good to know that your connection has since improved. If you need our help with anything else then please just re-post and we will happily investigate further.
Thanks again,
Take care.
Heather_J
