  • 25
dwplease
Message 1 of 26
Slow area 20 connection - 200 XL
Hi, I've been experiencing much slower speeds lately, it seems to be since upgrading to V6 tv box but may just be coincidence. Please can someone from VM have a look at my line?
  • 25
dwplease
Message 2 of 26
Re: Slow area 20 connection - 200 XL
  • 25
dwplease
Message 3 of 26
  • 10.82K
  • 308
  • 632
Message 4 of 26
Hi dwplease,
Thanks for posting back on the community.
Sorry to read you are having issues with your broadband speeds.
I've run some tests on your connection, the line and hub have come back as fine. There are no faults reported and the traffic on the network is running low, which is good.
The speed tests you completed were through wireless and as there can be so many different types of interference within the property that can have an impact on your speeds, can you try through a wired connection please?
Also can you post the network log from the router as I am unsure what is causing the packet loss that is showing in the BQM graph and would like to check this further?
Hope to hear from you soon
Sam
  • 25
dwplease
Message 5 of 26
My Broadband Speed TestWired speed test carried out today
  • 25
dwplease
Message 6 of 26
Fourth attempt... hopefully these are what you need, minus the MAC address. Refresh data Network Log Date And Time Error Number Event Description 2017-02-06 00:58:16.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-QOS=1.1;CM-VER=3.0; 2017-02-07 11:33:25.00 82000200 No Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0; 2017-02-09 14:43:23.00 68010100 DHCP RENEW sent - No response for IPv4;CM-QOS=1.1;CM-VER=3.0; 2017-02-10 14:06:40.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-QOS=1.1;CM-VER=3.0; 2017-02-12 22:12:40.00 82000200 No Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0; 2017-02-16 08:08:01.00 68010100 DHCP RENEW sent - No response for IPv4;CM-QOS=1.1;CM-VER=3.0; 2017-02-17 15:38:04.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-QOS=1.1;CM-VER=3.0; 2017-02-20 01:13:50.00 82000200 No Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0; 2017-02-24 13:19:31.00 68010100 DHCP RENEW sent - No response for IPv4;CM-QOS=1.1;CM-VER=3.0; 2017-02-24 21:08:58.00 82000200 No Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0; 2017-02-25 05:04:31.00 68010100 DHCP RENEW sent - No response for IPv4;CM-QOS=1.1;CM-VER=3.0; 2017-02-25 20:49:34.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-QOS=1.1;CM-VER=3.0; 2017-02-26 07:59:35.00 82000200 No Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0; 2017-02-28 21:00:48.00 68010100 DHCP RENEW sent - No response for IPv4;CM-QOS=1.1;CM-VER=3.0; 2017-03-01 11:35:57.00 82000200 No Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0; 2017-03-06 04:48:05.00 68010100 DHCP RENEW sent - No response for IPv4;CM-QOS=1.1;CM-VER=3.0; 2017-03-07 12:01:00.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-QOS=1.1;CM-VER=3.0; 2017-03-09 05:22:02.00 82000200 No Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0; 2017-03-10 13:07:12.00 68010100 DHCP RENEW sent - No response for IPv4;CM-QOS=1.1;CM-VER=3.0; 2017-03-11 09:03:30.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-QOS=1.1;CM-VER=3.0;
  • 25
dwplease
Message 7 of 26
My Broadband Speed Testfuller graph from second test just now if you need it
  • 10.68K
  • 314
  • 657
Message 8 of 26
Hello dwplease,
Thanks for the additional info Smiley Happy
Apologies again for this. The info you've provided is helpful, the next test we need to do is to put your Hub into Modem Mode and perform another speed test.
Hope to hear back from you soon,
Take care.
Heather_J
  • 25
dwplease
Message 9 of 26
Results for wired speed test with hub 3.0 in modem mode http://www.thinkbroadband.com/speedtest/button/14899448719249097165 - speed appears to have got slower(!). Am I being traffic managed or throttled by VM? My Broadband Speed Test
  • 25
dwplease
Message 10 of 26
Latest from superhub's error log since last posts:
2017-03-15 22:20:31.00 68010100 DHCP RENEW sent - No response for IPv4;CM-QOS=1.1;CM-VER=3.0;
2017-03-17 04:08:52.00 68010400 DHCP REBIND WARNING - Field invalid in response;CM-QOS=1.1;CM-VER=3.0;
2017-03-18 15:09:48.00 82000200 No Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0;
And power levels:
ChannelFrequency(Hz)Power (dBmV)SNR (dB)Modulation Channel ID
12987500000.238.6256 qam21
23227500000.538.9256 qam24
33147500000.238.9256 qam23
42907500000.238.6256 qam20
52827500000.438.9256 qam19
62747500000.438.9256 qam18
72667500000.538.9256 qam17
82587500000.538.9256 qam16
92427500000.438.9256 qam14
102347500000.438.9256 qam13
113067500000.238.9256 qam22
122507500000.538.9256 qam15
