Andylymn
Message 1 of 5
Slow and unstable broadband
Hi, been with virgin media on a 200mb contract since sept last year, since I joined the broadband has been well slow and very unstable 9 or 10 dropout daily. The speeds I get vary from12-25 my but normally under 20 and as I say very unstable. I have called and complained loads of times and at one point a engineer came and said he would test at the cabinet, he told me it was just as bad there. The trouble is nothing is being done about it ,is there anyone who can help I'm beginning to think that virgin can't provide a service fit for purpose !
  • 34
  • 6
Daren-ITsold
Message 2 of 5
Re: Slow and unstable broadband
Are those speeds hard-wired or wireless?
Daren, ITsold UK Website Support
Not affiliated with VM just trying to help where I can.
Andylymn
Message 3 of 5
Hi, thanks for the reply, I have tested using both wired and wireless connection, difference between the 2 is negligible, and just as unstable using both methods of connection.
  • 8.32K
  • 357
  • 586
Message 4 of 5
Hi Andylymn,
Welcome to the Community!
Sorry to hear you're having trouble with your connection.
I've run a diagnostic on your equipment and I can see an issue with your Downstream Power levels that will need to be adjusted by a technician. I've sent you a private message (purple envelope at the top right of your screen) so I can arrange an appointment.
Speak soon Smiley Very Happy
Josh
  • 34
  • 6
Daren-ITsold
Message 5 of 5
Did you solve this?
