  • 5
josemari87
Message 1 of 12
Slow and poor Internet connection
Hi everyone!
Yet another thread on slow connection. My area reference is 21. Since the 'speed boost' about two months ago, the speed connection is really poor -have to wait ages to load webpages-. Before that, we never had experienced such an extremely poor connection. Have tried to restart the router and PCs almost every day, but still no results.
Any ideas/advice on what to do?
Thanks!
Jose
Helpful Answers
  • 3.02K
  • 385
  • 957
Message 2 of 12
Re: Slow and poor Internet connection
Are you using a wired Ethernet connection to the VM hub or a wireless connection? Wireless is easily disrupted by a number of external factors, so a wired test is the best way to get a true picture of what speed your line is able to achieve. It also helps to pinpoint if the issue is with the wireless or your line.
Are you seeing slow speeds all day or only at peak times (typically 4pm-11pm weekdays and weekends)?
If you go to http://192.168.100.1/ to get the VM hub GUI. Don't login but instead click on Router Status which is either a button in the top right of the screen or a text link at the bottom of the screen depending on which hub you have. Click on the Downstream, Upstream and Network Log sections and copy & paste the figures from those screens and post them here. If you attach screen shots then they will not be visible to most of us until they are approved by a moderator so pasting text is better, don't worry about the formatting.
The community can have a look for you and see if anything in the figures looks wrong and advise accordingly. Or you can wait for the VM staff to pick up this thread in a few days and run checks on your line.
______________________
Scott
Disclaimer - I don't work for Virgin Media. I'm just another VM user trying to help out so my answers may be wrong :-) If you do like my answer please mark it as helpful as it may help others
All Replies
  • 3.02K
  • 385
  • 957
Message 2 of 12
Scott
  • 5
josemari87
Message 3 of 12
Thanks a lot for the answer. I have done what you just said and here I paste the figures:
Downstream                              DS-1       DS-2      DS-3             DS-4       DS-5        DS-6       DS-7           DS-8
Frequency (Hz)202750000210750000218750000N/A234750000 242750000 250750000258750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedUnlockedLockedLockedLockedLocked
Channel ID123N/A5678
Modulation256QAM256QAM256QAMUnknown256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.952000N/A6.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
N/AI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-1.27-1.10-1.89N/A-0.76-1.51-0.77-0.46
RxMER (dB)34.9335.6029.31N/A35.9736.8436.8437.64
Pre RS Errors8825011310228290N/A9892271514391625
Post RS Errors51333922543N/A1097322322936
Upstream                      US-1     US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID78N/AN/A75
Frequency (Hz)60300000N/AN/A32600000
Ranging StatusSuccessOtherOtherSuccess
Modulation16QAMN/AN/A16QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size4N/AN/A4
Power Level (dBmV)55.00N/AN/A55.00
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
First TimeLast TimePriorityError NumberDescription
08/04/2016 14:03:37 GMT08/04/2016 14:03:37 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:58:10 GMT08/04/2016 13:58:10 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:55:13 GMT08/04/2016 13:55:13 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:52:51 GMT08/04/2016 13:52:51 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:51:25 GMT08/04/2016 13:51:25 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:50:51 GMT08/04/2016 13:50:51 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:50:29 GMT08/04/2016 13:50:29 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:50:23 GMT08/04/2016 13:50:23 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:46:43 GMT08/04/2016 13:46:43 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:45:45 GMT08/04/2016 13:45:45 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:45:21 GMT08/04/2016 13:45:21 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:45:05 GMT08/04/2016 13:45:05 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:44:55 GMT08/04/2016 13:44:55 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:44:43 GMT08/04/2016 13:44:43 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:44:23 GMT08/04/2016 13:44:23 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:44:11 GMT08/04/2016 13:44:11 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:44:03 GMT08/04/2016 13:44:03 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:43:29 GMT08/04/2016 13:43:29 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:43:17 GMT08/04/2016 13:43:17 GMTWarning (5)84020200Lost MDD Timeout
08/04/2016 13:42:49 GMT08/04/2016 13:42:49 GMTWarning (5)84020200Lost MDD Timeout
Thanks!
Jose
  • 3.02K
  • 385
  • 957
Message 4 of 12
Hi Jose
The upstream power levels are too high at 55, the max recommended is 50.  The downstream is not locked on to all eight channels so that is not good.
Can you turn the hub's power off for a couple of minutes then back on again and copy and post the same screens, just to see if that makes a difference.
Scott
  • 5
josemari87
Message 5 of 12
Thanks for your quick answer. I have tried to turn the hub off por a couple of minutes and here you have the stats:
Frequency (Hz)202750000210750000218750000N/A234750000242750000250750000258750000
J=17
I=12
J=17
I=12
J=17
N/AI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-1.26-1.08-1.88N/A-0.68-1.52-0.84-0.45
RxMER (dB)34.9335.6028.75N/A35.6036.8436.6137.94
Pre RS Errors71622409285358N/A171211104281083
Post RS Errors30228816215N/A3023202971022
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
  • 3.02K
  • 385
  • 957
Message 6 of 12
Nothing has improved, so it looks like you need an engineer to visit and sort out the upstream power levels and investigate why the downstream is not locking on to all 8 channels.
Before doing that it might be worth a check on the service status page to make sure there is not an area fault:
https://my.virginmedia.com/faults/service-status
You can call VM on 150 (from a VM phone line) or 0345 454 1111 and try to book an engineer or wait a few days for the VM forum staff to pick up this thread and they can help arrange an engineer appointment.
Scott
  • 5
josemari87
Message 7 of 12
Thanks a lot for this, very helpful. I have checked but there are no issues in my areas, so I will try to book an engineer. Smiley Frustrated
Jose
  • 10.82K
  • 309
  • 632
Message 8 of 12
Hi Jose
I am sorry to see that you're experiencing slow broadband speeds. I know how frustrating this can be.
I can see from your account that you had an engineer visit to check this for you. The upstream power levels are now at 49 dBmV and all downstream power levels are locked onto 9 channels.
Have you noticed an improvement with your connection?
Let us know how you get on
Sam
  • 5
josemari87
Message 9 of 12
Samantha_L wrote:
Hi Jose
Sam
Yes, the engineer came and it's now fixed. Thanks a lot for your help!
Jose
  • 7.51K
  • 305
  • 676
Moderator
Moderator
Message 10 of 12
Moved:
