carl1711
Slow WiFi Speeds
Hi I am new to Virgin after having Sky for the passed 10 years. As I work from home I was attracted to the 200Mps speeds.
After connecting everything up and getting started I have wired speed of upto and sometimes in excess of 200Mbps.
Switch to WiFi and that is a totally different story I am lucky to get 20Mbps, I am no technical geek so any help with overcoming this problem would be greatly appreciated. I never had this problem with the Sky Home Hub so frustrated that I have the problem with the new Virgin box.
Any help greatly appreciated. Thanks
  • 5.67K
  • 291
  • 1.25K
Re: Slow WiFi Speeds
You've already said the solution. Wire up.
All posts made are personal opinions as I do not work for VirginMedia.
Kudo's a post if you find it useful and want to say thanks
Mark a post as a helpful answer if it answers your question
carl1711
The whole point of wireless is just that! No wires trailing through the house.
Thanks for the input though!!!
