  • 9
JT2017
Message 1 of 17
Slow VM Broadband, help required
Evening
Another post re internet speed.
For the last few weeks my internet speeds have dropped so much its almost impossible to use any online service. For example - I've been looking for a car and to load the carpeople web site and search its taking approx 5 min's between pages??
I'm paying for 'Super Fibre 70' but used a simple speed checker (Speedtest by Oolka) and I'm struggling to get over 2mbps?  This is morning, noon and night??
Having read a few posts - I've logged into the hub - 192.168.100.1 and under router status/downstream I'm getting the below info - Does all seem ok? or do I have a problem???
Downstream
DS-1
DS-2
DS-3
DS-4
DS-5
DS-6
DS-7
DS-8
Frequency (Hz)
323000000
267000000
275000000
283000000
291000000
299000000
307000000
315000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Channel ID
82
75
76
77
78
79
80
81
Modulation
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
Symbol Rate (Msym/sec)
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
Interleave Depth
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)
-3.21
-3.38
-3.03
-2.70
-2.78
-2.73
-2.91
-3.12
RxMER (dB)
37.36
36.17
36.17
36.84
37.36
37.36
37.36
37.94
Pre RS Errors
3952
6574
4482
801
321
359
297
287
Post RS Errors
273
288
296
277
319
342
293
283
Helpful Answers
  • 8.32K
  • 356
  • 585
Message 6 of 17
Re: Slow VM Broadband, help required
Hi JT2017,
Welcome to the Community!
Really sorry to hear you're experiencing slow speeds.
I've run a diagnostic on your equipment and nothing stands out at the moment. All your levels are within spec and there are no issues with the network in your area.
Are you connecting wired or wirelessly?
I'd like you to run a speed test with the hub in Modem Mode to see what kind of results we get.
Speak soon Smiley Very Happy
Josh
All Replies
  • 17
aladdinPK
Message 2 of 17
I'm paying for 100 meg and getting stupid slow speeds as well VM needs to sort this out everyone needs to get together....its ridiculous they are trying to keep up with sky with the v6 when there broadband is not much faster than dialup !!!!
  • 17
aladdinPK
Message 3 of 17
Everyone with problems in Essex should all go to Basildon and protest outside virgin until it is sorted or we are compensated in some way for being ripped off!!
  • 9
JT2017
Message 4 of 17
Thanks aladdinPK
I'm in Barnsley, South Yorkshire - appears to be a nationwide issue..
Speed currently stable at 2.61mbps.... pah!
  • 9
JT2017
Message 5 of 17
Yet another day of slow broadband - check at 1900hrs - struggling to reach 2mbps...
  • 8.32K
  • 356
  • 585
Message 6 of 17
Hi JT2017,
Josh
  • 9
JT2017
Message 7 of 17
Hi Josh_RW
I've connected using an Ethernet cable and put the router in to modem mode.. result as below - however speeds have improved somewhat - last check prior to modem mode using speedtest from my mobile  - clocking at 42.98 download and 5.31 upload.
Downstream
DS-1
DS-2
DS-3
DS-4
DS-5
DS-6
DS-7
DS-8
Frequency (Hz)
299000000
267000000
275000000
283000000
291000000
307000000
315000000
323000000
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Channel ID
79
75
76
77
78
80
81
82
Modulation
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
Interleave Depth
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)
-2.53
-3.12
-2.87
-2.50
-2.55
-2.73
-2.95
-3.05
RxMER (dB)
37.09
36.39
36.39
36.84
36.61
36.61
37.94
36.61
Pre RS Errors
277
295
308
284
277
277
277
294
Post RS Errors
277
295
307
284
277
277
277
292
  • 9
JT2017
Message 8 of 17
Further to my last - check of speed at https://www.uswitch.com/broadband/speedtest/results
Postcode*** 0SZ
Your download speed18.0Mb
Your upload speed5.5Mb
Speeds seem all over the place?
I agree there better than the 2mbps I was getting but still up and down??
[MOD EDIT: For your security personal and private information has been removed from this post. Please review the Forum Guidelines]
  • 10.62K
  • 311
  • 654
Message 9 of 17
Hey there JT2017,
Thanks for getting back to us with additional results, it's much appreciated.
Apologies again for the speed problems, are you seeing the reduction on multiple devices or just the one? Also, do you get similar results when you test from speedtest.net?
Hope to hear back from you soon,
Take care.
Heather_J
  • 9
JT2017
Message 10 of 17
Morning Heather_J
Yes its over multiple devices - iPhone, ipad, firestick and PC anything that needs a connection..
I use spedtest.net and have used it on both the iPhone, ipad and pc....
Ive just finished work and the screenshot below was taken just now on my PC and its shocking considering its now 0400 in the morning.
[MOD EDIT: Inappropriate Image removed (Contains IP address), please review the Forum Guidelines]
