  • 5
craig_howieson
Slow Speed NG15
Getting very slow speeds in the NG15 area at night. I know it's a contested area but it's got really bad the last 3 weeks to the point you can't have 2 people on you tube.
I've tried to ring the contact centre about 8 times now but they cut me off after waiting for the required time. Is there an issue with the call centre as well?
  • 5
craig_howieson
Re: Slow Speed NG15
Can someone on the VM team also let me know what the issue with call centre is please? I cannot get through I get constantly cut off
  • 10.82K
  • 308
  • 631
Re: Slow Speed NG15
Hi there craig_howieson,
I'm sorry to read that you are having issues with your broadband connection.
Looking at your connection, I can see the high peak time traffic fault in your area that you mentioned. The reference number is F004175778 and has a review date of 1st March 2017.
There is also an SNR (signal to noise ratio) fault reported which is causing intermittent connection. With a reference number of F004914970 and has a review date of 28th December.
By all means post back here for an update in regards to the faults and we can check this for you.
Sam
