  • 15
desperado126
Slow Speed 7mb instead of 150mb
Hi so basically i know that expecting a full 150mb download speed is not very realistic as it depends on number of factors but lately I've been getting really slow broadband speed and many times even simple thing like watching netflix or twitch.tv is really bad as it keeps on loading so as my title says im getting anything between 7mb to 10mb instead of 150mb before i used to get 142mb using my wired connection and I've been using both wired connection and wireless and yet it still has same problem my area code is 21 i've checked if there are faults reported but none are so here is my router status
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 298750000 266750000 274750000 282750000 290750000 306750000 314750000 322750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 13 9 10 11 12 14 15 16
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV) 9.22 9.28 9.33 9.46 9.46 9.16 9.15 9.32
RxMER (dB) 38.26 38.26 38.26 38.26 38.98 38.61 38.26 38.26
Pre RS Errors 3652 3826 694 488 327 1028 345 317
Post RS Errors
316 313 329 275 290 997 312 296
Upstream   US-1 US-2 US-3 US-4
Channel Type N/A 2.0 2.0 N/A
Channel ID N/A 6 5 N/A
Frequency (Hz) N/A 39400000 46200000 N/A
Ranging Status Other Success Success N/A
Modulation N/A 16QAM 16QAM N/A
Symbol Rate (Sym/sec) N/A 5120000 5120000 N/A
Mini-Slot Size N/A 4 4 N/A
Power Level (dBmV) N/A 43.50 43.75 N/A
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 8 2 0
T4 Timeouts 0 0 0 0
First Time Last Time Priority Error Number Description
22/01/2017 18:39:05 GMT 22/01/2017 18:39:05 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
20/01/2017 23:11:12 GMT 20/01/2017 23:11:12 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
20/01/2017 20:20:09 GMT 20/01/2017 20:20:09 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
20/01/2017 19:45:12 GMT 20/01/2017 19:45:12 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
20/01/2017 11:44:15 GMT 20/01/2017 11:44:15 GMT Error (4) 68010302 DHCP WAN IP -#######
20/01/2017 11:43:35 GMT 20/01/2017 11:43:35 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
20/01/2017 11:43:22 GMT 20/01/2017 11:43:22 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
20/01/2017 11:43:14 GMT 20/01/2017 11:43:14 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
20/01/2017 11:43:12 GMT 20/01/2017 11:43:12 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
20/01/2017 11:43:11 GMT 20/01/2017 11:43:11 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
20/01/2017 11:43:05 GMT 20/01/2017 11:43:05 GMT Error (4) 68000407 TOD established
20/01/2017 11:42:48 GMT 20/01/2017 11:42:48 GMT Notice (6) 84000510 Downstream Locked Successfully
20/01/2017 11:42:41 GMT 20/01/2017 11:42:41 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
20/01/2017 11:41:41 GMT 20/01/2017 11:41:41 GMT Critical (3) 84000500 SYNC Timing Synchronization failure - Loss of Sync
20/01/2017 11:41:40 GMT 20/01/2017 11:41:40 GMT Critical (3) 84000500 SYNC Timing Synchronization failure - Loss of Sync
20/01/2017 11:41:33 GMT 20/01/2017 11:41:33 GMT Critical (3) 84000500 SYNC Timing Synchronization failure - Loss of Sync
20/01/2017 11:41:13 GMT 20/01/2017 11:41:13 GMT Critical (3) 84000500 SYNC Timing Synchronization failure - Loss of Sync
20/01/2017 11:41:12 GMT 20/01/2017 11:41:12 GMT Critical (3) 84000500 SYNC Timing Synchronization failure - Loss of Sync
I hope this helps if anyone can give an insight as to what could be the problem would greatly appreciate it
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 15
desperado126
Re: Slow Speed 7mb instead of 150mb
I see no one knows what could be the problem hmm... maybe i should really switch providers since i noticed alot of people in 21 area experience similar issues
  • 15
desperado126
seriously this is getting ridiculous now my broadband is not as advertised yet im paying for a service that isn't delievered I think I will have to move to BT or SKY
  • 10.62K
  • 311
  • 654
Hello desperado126,
Sorry for not replying sooner, when you continue to post on the same thread it alters your position in our queue as we respond to posts based on the date of the last post.
I've just checked your connection and I can see that we currently have an active SNR fault in your area. This fault can cause intermittency and slow speeds. The fault ref is: F005018319 and were hoping it will be resolved on the 6th Feb. Additionally your downstream power levels are out of range when I check today. If this is still an issue after the area fault is been resolved, I will arrange for an engineer to call around.
Please bump this thread on or after the 6th with an update for us.
Thanks again,
Take care.
Heather_J
